Date/Time: Wed, 15 Jan 2025 21:44:01 +0000
ACSIL Backtesting of multiple triggers and/or symbols
View Count: 932
[2017-09-16 00:52:35] |
User553714 - Posts: 184 |
Hi, A while back SC mentioned that there were some improvements that might be made in this area, see here; ACSIL BackTesting Functions It would be great if you can use ACSIL to backtest multiple trade triggers and or Symbols; my vision would be to configure an inputs file with the triggers/symbols you wanted to backtest and let it run over night as Bast testing usually takes quite a bit of time escpecially when testing systems over long periods of time; In order to be able to do this some new ACSIL funtions would need to be implemented which allowed you to take control of the Back testing process including status checking. Has any progress been made towards the goal of testing for multiple triggers and or symbols? Thanks. |
[2017-09-18 16:40:34] |
No not yet. We basically are about a year behind on the ACSIL improvements and additions.
