Date/Time: Wed, 15 Jan 2025 21:35:08 +0000
real time chart - incorrect data
View Count: 941
[2017-09-15 20:11:55] |
jimkass - Posts: 5 |
I have followed the instructions and IB TWS accepted the connection. The system deducted $5 for the feed so I assume that I set it up correctly. However, The real time ES futures data is not correct. huge gaps on the 5 min chart. Also I do not the see the 'M' signal next to the ticker that would indicate the Sierra Real time feed. Thank you |
Capture_ESZ17.JPG / V - Attached On 2017-09-15 20:07:43 UTC - Size: 89.93 KB - 291 views Attachment Deleted. |
[2017-09-15 20:14:00] |
You need to activate the CME Group exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-15 20:43:39] |
I thought that I had done it. Anyway, signed the form and activated. The [M} showed next to the ticker. Still the ES futures intraday shows gaps. I downloaded a few times but still not good. The NQ chart is fine though. Please advise. Thanks much. |
[2017-09-15 21:53:43] |
Re-download the data in the chart that is missing data by selecting Edit >>Delete All Data and Download. If there still is a problem provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-15 21:53:55
[2017-09-15 21:55:04] |
Also refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Missing or Incomplete Intraday Chart Data Refer to the post above also. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-15 21:55:34
