Date/Time: Wed, 15 Jan 2025 21:30:29 +0000
weekend
View Count: 1489
[2017-09-15 17:02:29] |
Dennis B. - Posts: 277 |
Is there a way to not have the Sat/Sun spaces on the intra-day charts ? Little annoying.
[2017-09-15 18:06:09] |
This is not normally the case. Make sure this option is not enabled: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#IncludeColumnsWithNoData Otherwise, what you are describing makes no sense. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-17 15:48:40] |
Did what you said, checked box to not have weekend columns if no data. Still have Sat'Sun columns on my intra-day charts (es) Must be bug.....
[2017-09-17 21:06:36] |
No it is not a bug. What we referred you to is Include Columns with No Data: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#IncludeColumnsWithNoData Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-18 14:52:03] |
Did what you said, checked box to not have weekend columns if no data. Still have Sat'Sun columns on my intra-day charts (es) Tried again every which way no luck. Too complicated to upload chart (for me) Forget about it, I'll live with it. Like I said, annoying but not critical....thank you.
[2017-09-18 19:12:09] |
The option we referred to is Include Columns with No Data. If indeed you are having Saturday data in the chart and Sunday data before the Sunday open, that would be from IQ Feed which we see you are using. Consider using the Sierra Chart Exchange Data Feed which is less expensive and overall better: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
