Date/Time: Wed, 15 Jan 2025 19:32:46 +0000
sierra data feed - 2 week trial - ES not updating
View Count: 1089
[2017-09-15 15:31:08] |
jimkass - Posts: 5 |
Hello, New user here. I cant get real time ES data (december futures). I believe that I have followed the instructions, even put $50 into my account. I have requested 2 weeks trial. Please advise. Thank you regards |
[2017-09-15 16:56:13] |
If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-15 16:58:33
[2017-09-15 16:58:40] |
The prior post has been updated.
[2017-09-15 17:23:59] |
Yes, I do have a funded account with Interactive Brokers. However I want to get data from the Sierra feed, not from Interactive. I have updated my information but still don't get real time ES data. |
[2017-09-15 17:33:29] |
Therefore, you need to follow the instructions in this section here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
