Date/Time: Wed, 15 Jan 2025 22:01:37 +0000
VbP indicator not restarting properly after contract rollover
View Count: 1225
[2017-09-15 14:58:03]
User832792 - Posts: 17
Could you guide me why me VbP indicator doesn't restart at 9:30AM EST after I rolled my ES contract? I uploaded a screenshot of the settings. If I change back the contract to the original, the VbP works fine again.
imageset1.png / V - Attached On 2017-09-15 14:56:25 UTC - Size: 41.34 KB - 378 views
imageset2.png / V - Attached On 2017-09-15 14:56:34 UTC - Size: 41.57 KB - 311 views
imageset3.png / V - Attached On 2017-09-15 14:56:52 UTC - Size: 48.42 KB - 412 views
[2017-09-15 17:54:51]
So we can understand this better, scroll the chart to where the Volume by Price study is displayed and provide an image of the chart or Trade DOM, by following these instructions:
[2017-09-16 09:38:10]
Here you go:
http://www.sierrachart.com/image.php?Image=1505554600698.png
[2017-09-17 02:28:48]
At this point we are going to need to get a Chartbook with a single chart to do some testing. Follow the instructions here:
[2017-09-18 17:56:33]
Great. Please find it attached.
attachmentVbPSupport.cht - Attached On 2017-09-18 17:55:47 UTC - Size: 30.46 KB - 385 views
[2017-09-19 00:45:04]
Do you notice this problem with a chart replay? We tested it with a replay and could not reproduce it.
The volume profile did reset at 16:15.
We also set the profile to be left aligned and we enabled the option to draw the enclosing outline to make it easier to understand what bars it is representing.
[2017-09-19 13:35:14]
That is great to hear, that everything is working. So what do I need to change in the setting to get it restart at 9:30AM EST, market open (as was the original case before rolling the chart over) instead of 16:15?
[2017-09-19 18:31:31]
OK now we understand the problem. The chart Session Times have changed.
Select Chart >> Chart Settings and disable Use Evening Session. Set the Start Time to 9:30:00.
Set the End Time to 9:29:59.
