Date/Time: Sun, 24 Nov 2024 02:59:03 +0000
QuoteBoard
View Count: 1596
[2013-09-06 07:46:50]
User27812 - Posts: 15
Hello Support,
I think there may be an issue with the quoteboard. For example, every time prices changes up, it doesn't highlight in green and vice versa for down. I have attached the image below.
I've changed the colours under Graphic Settings but no luck with that. Any help will be helpful.
Thanks.
http://www.sierrachart.com/image.php?l=1378453369245.png
[2013-09-06 23:06:07]
The color settings you are referring to affect the daily Net Change value.
[2013-09-07 02:24:23]
Documentation for Quote Board colors can be found here:
http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#SettingColors
