Date/Time: Wed, 15 Jan 2025 21:48:51 +0000
Study for Price
View Count: 1128
[2017-09-15 13:15:09] |
User94740 - Posts: 333 |
I have checked for an existing study in sc which is similar to the TPO study, but instead of time, it would use price such that the amount of times a price is traded. At the moment, sc has time by price(TPO), volume by price, but nothing on number of trades by price. Would appreciate your feedback.
[2017-09-15 18:01:21] |
What we can do is add a Number of Trades Volume Bar Calculation Method to the Volume by Price study.
[2017-09-15 18:32:04] |
I would imagine the distribution curve would still be dependent on volume and only show the amount of trades at the volume by price. Correct?
Date Time Of Last Edit: 2017-09-15 18:32:55
[2017-09-15 18:48:58] |
No, that is not correct.
[2017-09-16 20:27:03] |
if it is easy to do, then it will bring almost all elements of trade distribution into context.
[2017-09-16 21:03:09] |
This has already been released in the prerelease.
