Date/Time: Thu, 16 Jan 2025 19:43:25 +0000
ACSIL mouse click key modifier
View Count: 1627
[2017-09-15 12:46:43]
dtl-saw - Posts: 79
I'm using custom buttons on a control bar + mouse clicks to create drawings and configure chart behaviors. To keep the number of buttons used down I would like to use a key modifier for mouse clicks.
For example, i use a custom button to enter a drawing mode and then use a mouse click to define an index on the chart for constructing a drawing. If I could combine <CTRL> key + a mouse click then I could define another different behavior from just the mouse click and which saves from using another button.
Do you have that available in ACSIL to combine special function keys like: <ALT>, <CTRL>, <SHIFT> to combine with left mouse clicks?
[2017-09-15 17:47:06]
We will see about adding flag variables to ACSIL to indicate these particular keyboard states.
Date Time Of Last Edit: 2017-09-15 17:47:16
[2017-11-25 19:38:57]
dtl-saw - Posts: 79
It's been awhile since I posted, did you implement this requested feature?
This capability will be a big benefit for everyone writing ACSIL functions.
Regards
[2017-11-25 23:45:54]
Yes this has been done for some time now:
  uint16_t sc.SupportKeyboardModifierStates;
  uint16_t sc.IsKeyPressed_Control;
  uint16_t sc.IsKeyPressed_Shift;
  uint16_t sc.IsKeyPressed_Alt;
We will have documentation available as soon as possible for these.
[2017-11-26 02:09:36]
dtl-saw - Posts: 79
Fantastic! Thanks for supporting this feature.
[2017-11-26 02:36:04]
You will need to set :
sc.SupportKeyboardModifierStates=1;
