Date/Time: Wed, 15 Jan 2025 19:34:44 +0000
How do i get rid of this info on DOM?
View Count: 882
[2017-09-15 07:55:25] |
phaedonk - Posts: 352 |
Cant figure it out. See pic, thanks.
[2017-09-15 08:55:15] |
If you are referring to the market depth quantities, refer to: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-15 11:23:05] |
Sorted. It was the Chart DOM settings. Thanks.
