Date/Time: Wed, 15 Jan 2025 21:58:32 +0000
Bund Daily Chart Painting Extra Daily Bar before the Open
View Count: 1055
[2017-09-15 05:08:50] |
User93757 - Posts: 61 |
Hi, I've had this issue for some time, just getting around to asking. Before the open of the Eurex, the Bund Prints an extra bar for the current day. Once the Eurex Opens, and i reload/Recalculate; the chart is ok. It is only before the Open... My chart time is set to london... Please see attached chart... Ty, http://www.sierrachart.com/image.php?Image=1505451760345.png Added the chart with description; http://www.sierrachart.com/image.php?Image=1505452449570.png Date Time Of Last Edit: 2017-09-15 05:15:02
[2017-09-15 18:27:09] |
Refer to help topic 12.12: http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.12 We will see if we can solve this problem with CQG but CQG is not a well designed data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-18 17:37:02
[2017-09-18 10:48:40] |
Thank you, and i trust sierra's judgement on the CQG datafeed; Therefore i have two more questions in relation to this issue... 1) Previously, when it came to Bid/Ask Volume... You mentioned at the time, that CQG was probably more accurate then Sierra's on the EUREX. And that this may change... Are there any updates on that front? General Data Question | Post: 102347 2) I know you've written good things about CTS – T4, i now have an opportunity to use the feed. Do you have any comment on their Eurex feed. Any idea how their Bid/Volume data is, and will this also help the current issue i have with the Bund. Ty, |
[2017-09-18 17:35:15] |
1. We have changed the backend data feed used for the Sierra Chart EUREX data. How much of a difference that makes, we do not know. You would need to evaluate this. 2. Keep in mind there are two connection models for CTS. The best method is the new low-cost connection model: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel We will see if we notice this duplicate bar problem with the Sierra Chart Exchange Data Feed and EUREX data. 3. Also we did implement a change to try to solve the duplicate bar problem with CQG. Update to the latest "Prerelease" following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-18 17:35:56
[2017-09-19 08:47:27] |
CQG seems to be working with the daily bar now... Ty,
