Date/Time: Wed, 15 Jan 2025 19:59:29 +0000
Issues with Chart Windows (Prerelease 1611)
View Count: 859
[2017-09-15 04:11:12] |
tobi - Posts: 351 |
Prerelease 1611 has the following issues with chart windows: - With several chart windows open an some minimized, when switching between chartsbooks (chartbook tabs), all the "minimized" chart windows are visible (not minimized any longer). - With chart windows title bars not enabled, when switching between chartbooks, the title bars are shown for a short moment. - When switching between chartbooks, the MDI Window Tabs are not shown for a short moment. Prerelease 1610 was fine. In one or two prior prereleases (1609 ?) the issues had occured there too. |
[2017-09-15 09:01:29] |
This is all resolved in the latest revision except for this: - When switching between chartbooks, the MDI Window Tabs are not shown for a short moment.
Not sure we want to do anything about that because that is by design for reliable management of tabs. The only thing that concerns us is that the minimized windows become out of place when the tabs appear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
