Date/Time: Wed, 15 Jan 2025 21:46:00 +0000
Plot Chart of Spreads and Butterflies
View Count: 1521
[2017-09-14 20:30:17] |
sigmadict - Posts: 95 |
Hello, I would like to plot the Chart of the Spreads of the Canadian Ba's 3 months (known as BAX Futures, Symbol CE). For example, I would like to plot the CEZ17 CEH18 Spread (I know I can use the difference with bars Study), or the CEZ17 CEH18 CEM18 Butterfly. Those are traded products on the Montreal Exchange (TMX). Is it possible to directly plot the Chart of the products (Spreads and Butterflies) with a specific symbol ? Thank you Regards |
[2017-09-15 02:54:53] |
There are spreads available and we will set these up in the next couple of days for the Montréal futures exchange.
[2017-09-19 02:51:33] |
These particular futures spreads are now operational. However, the historical data only begins as of 2017-09-19. Update the Symbol Settings as explained here if Sierra Chart is not running: Global Symbol Settings: Update Symbol Settings Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads You can get the symbols for them through File >> Find Symbol >> Futures Spreads (SC Exchange Data) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
