Date/Time: Wed, 15 Jan 2025 20:00:02 +0000
Bitmex attached order error
View Count: 1898
[2017-09-14 20:05:02] |
N!co - Posts: 140 |
Hi, sending a market order with attached stop and limit i am getting this error message BitMEX order update (Order reject). Info: BitMEX Trading Master - DTC order update (Order reject). Info: (monitor.ml.Error (Failure "ValidationError: Order price is above the liquidation price of current short position") ("Raised at file \"pervasives.ml\", line 32, characters 17-33" "Called from file \"src/deferred0.ml\", line 61, characters 64-69" "Called from file \"src/job_queue.ml\", line 159, characters 6-47" "Caught by monitor try_with_or_error")). Internal Order ID: 5260. Service Order ID: 205413. Symbol: XBTUSD-BMEX | 2017-09-14 21:20:51 * |
[2017-09-15 09:40:59] |
We submitted this to BitMEX and this is what they said: That error means that the user placed an order higher than their liquidation price, so it could never possibly execute
A liquidation cancels all orders in that symbol Although you are saying this was a market order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-15 09:41:18
[2017-09-15 11:49:56] |
N!co - Posts: 140 |
the order was a market order and was filled ! just the attached orders were deleted i haven't realy been able to track down exactly what is happening but its my believe sierra/bitmex are looking at 2 different prices, because i also had it happen that my attached orders where filled ( closed) immediately also the p/l on open position can show green , while it is negative ... Date Time Of Last Edit: 2017-09-15 11:58:22
