Date/Time: Wed, 15 Jan 2025 19:49:58 +0000
Evening Session Background Color
View Count: 2832
[2017-09-14 20:02:59] |
lpfin123 - Posts: 59 |
Good Afternoon, I'd like to also see the evening session bars on my chart (which I can), but I would like to have the background color different than the normal session. Is there a way to do this or is it possible to add this option under "graphic settings"? Right now, I know I can have an horizontal line, but I would like something even more visual if possible. Thank you |
[2017-09-15 06:29:54] |
User630996 - Posts: 25 |
Or this one: Time Range Highlight Date Time Of Last Edit: 2017-09-15 07:21:40
TimeRangeHighlight.PNG / V - Attached On 2017-09-15 06:29:09 UTC - Size: 65.17 KB - 569 views |
[2017-09-15 09:27:42] |
We recommend using either of these two studies: Time Range Highlight Session Indicator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
