Date/Time: Wed, 15 Jan 2025 19:34:58 +0000
Market Stats
View Count: 1016
[2017-09-14 16:41:26] |
User662435 - Posts: 8 |
Are historical S&P 500 daily market stats available prior to 2014? It appears they might be according to the following? Thanks. "The Symbols documented on this page have data which go back to approximately the beginning of 2014 except for the following which have more history: From 2009-08-28 for NISS-NYSE. From 2008-08-07 for TICK-NYSE. To access all of the available historical data for any of the market statistics symbols, follow the Downloading / Viewing More Historical Intraday Data. Market Statistics symbols are also provided with the Sierra Chart Historical Data Service which uses data from the Barchart Data service. These are completely separate market statistics symbols. Follow the instructions on the Sierra Chart Historical Data Service page to use that service. You can open Historical Daily or Intraday charts for any of the Sierra Chart Historical Data Service Market Statistics symbols using that service." |
[2017-09-14 17:22:08] |
No, they are not.
