Date/Time: Wed, 15 Jan 2025 20:01:38 +0000
Trading Keyboard Shortcuts
View Count: 2868
[2017-09-14 08:44:34] |
User401662 - Posts: 16 |
Hello, I would like to trigger a stop order on a chart using the mouse position with a keyboard shortcut. I don't find the stop order option in Global Settings > Customize Keyboard Shortcuts > Trading Keyboard Shortcuts. Is it supported? Thanks for your help. |
[2017-09-14 17:38:55] |
This is not supported. You can right-click on the chart and select a Stop order. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#EnteringOrdersFromTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-15 06:04:43] |
Ok, I knew I could right-click but I find it a bit slow and error-prone when scalping. Thank you. |
