Date/Time: Wed, 15 Jan 2025 22:02:09 +0000
overlay
View Count: 1034
[2017-09-14 06:17:07] |
User882442 - Posts: 17 |
hello, is possible to overlay difference chart to second chart? something like pictures. i know that is possible make overlay for one instrument but i need overlay difference between 2 instruments. |
GBPUSD [CBV] [M] 1 Min #9 2017-09-14 08_00_22.927.png / V - Attached On 2017-09-14 06:16:56 UTC - Size: 53.2 KB - 312 views |
[2017-09-14 18:07:49] |
Go to a new chart and add the Difference (Single Line) study, configure its Inputs as required and set it to Display as Main Price Graph. Refer to: Difference (Bar or Single Line) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-15 18:30:41] |
thank you for answer. i have next question. difference study acts as a difference between two instruments (gbpusd - eurusd). And is there such a study that lets you divide one entity by another gbpusd / eurusd? Date Time Of Last Edit: 2017-09-15 18:32:37
[2017-09-15 19:08:06] |
Use the Ratio study for this: Ratio (Single Line) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
