Date/Time: Wed, 15 Jan 2025 21:17:01 +0000
Time Scale
View Count: 887
[2017-09-14 03:03:49] |
User22414 - Posts: 66 |
I have an incorrect time setting on the x-axis. The entry in Chart Settings -> Session Time is correct for the euro round the clock at 00:00:00 to 23:59:95 but is wrong in the chart. For example, it is now 4:56 MESZ but in the chart of the EUR the current price of 1.18820 is displayed on the x-axis at 2:50:32. This has always been correct so far, and has always been displayed correctly without any additional settings. Where is the mistake? |
[2017-09-14 03:06:51] |
Make sure the time zone is set correctly: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
