Date/Time: Wed, 15 Jan 2025 21:00:44 +0000
Cancellation of service
View Count: 749
[2017-09-14 01:55:36] |
User136567 - Posts: 1 |
I would like to cancel my subscription to Sierra Chart Services. Thank you, James Rawles
[2017-09-14 03:00:49] |
There is nothing special that needs to be done in this case. It is going to end on 2017-10-14. So you are all set at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
