Date/Time: Wed, 15 Jan 2025 19:34:17 +0000
ATR Stop
View Count: 2388
[2017-09-14 00:48:07] |
User989662 - Posts: 1 |
Hello Support: I would like to Use ATR Stop (a.k.a) volatility stop in Sierra chart. How do I achieve this? |
[2017-09-14 06:42:11] |
Marmany - Posts: 307 |
Use SuperTrendStop Study
[2017-09-14 18:13:33] |
We need to know the particular formula you are looking for. We do not know exactly what ATR Stop does exactly. Sierra Chart does have an Average True Range and a Volatility study. Refer to: Average True Range Volatility - Historical Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-14 21:48:38] |
Sawtooth - Posts: 4153 |
'Kiwi's Trailing Stop' is also based on the ATR.
