Date/Time: Wed, 15 Jan 2025 21:52:19 +0000
DOM global trade clear and ladder recenter
View Count: 1690
[2017-09-13 20:44:31] |
TraderD - Posts: 56 |
Hello, Is it possible to clear current or recent trade data from all DOM's at the same time? Can that be done with price ladder recenter as well? I don't see anything in the settings or support board, but perhaps you know a workaround. Thanks, Darryl |
[2017-09-15 08:56:32] |
Is it possible to clear current or recent trade data from all DOM's at the same time? Not for different symbols. Only for a single symbol. Refer to:https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ColumnDescription_ResettingResettableTradeChartDOMColumns Can that be done with price ladder recenter as well? Yes, refer to:Trade Menu: Re-Center Trade DOM Scales (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-18 17:44:28] |
Thanks. Would the development team consider adding a hotkey/button to clear current/recent trade data from all DOM's? Would be very helpful when trading older flow in correlated markets like the treasury curve.
