Date/Time: Wed, 15 Jan 2025 19:42:33 +0000
butterfly spread charts
View Count: 1979
[2017-09-13 19:41:20] |
User420048 - Posts: 17 |
Hi, I am relatively new to sierra charts. How do I set up a butterfly chart. I understand how to set up a spread chart with the "difference" study. Does anyone know how to use that study for three spreads. For instance, if I wanted to chart wti: vx,xz,zf. Any help would be greatly appreciated. Thanks, John |
[2017-09-14 05:31:30] |
You can use the Spread-Butterfly study: Spread - Butterfly Also refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
