Date/Time: Wed, 15 Jan 2025 19:34:14 +0000
disable drawing tools
View Count: 1374
[2017-09-13 19:32:58] |
User780238 - Posts: 45 |
Is there a way to disable how tools/drawings snap on to the chart ? I am using renko bars at 987T time frame..and nothing draws where I want it.. |
[2017-09-14 05:33:27] |
Refer to: Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
