Date/Time: Tue, 29 Sep 2026 21:23:49 +0000
Question on Hurst exponent
View Count: 1525
| [2017-09-13 19:18:13] |
| bala - Posts: 74 |
The HURST exponent subgraph returns for an asset values between 0.5 and 1.3. The HURST values are supposed to be bounded by values (0.0<H<0.5, 0.5, 0.5>H>1). I understand that Sierra has implemented a specific version, question is how do I interpret a data - H between 0.5 and 1.3 for entire 2 years? Thanks for help. |
| [2017-09-14 05:32:04] |
We need some time to look into this.
| [2017-09-15 17:25:37] |
| SC Support Tom - Posts: 450 |
Hello bala, As you noted, the Hurst exponent should be between 0 and 1 (with 0 < H < 0.5 indicating an anti-persistent time series, and 0.5 < H < 1 indicating a persistent time series). Any of the existing algorithms for computing the Hurst exponent are estimations, and some of those estimations yield H > 1 for a given time series. We are unable to offer an interpretation for this case. Date Time Of Last Edit: 2017-09-15 21:10:42
