Date/Time: Wed, 15 Jan 2025 19:39:25 +0000
Custom DOM not working anymore
View Count: 955
[2017-09-13 18:21:42] |
User745051 - Posts: 17 |
Hi guys, since my computer change and update this custom DOM doesn't load correctly anymore. can someone help? Feel free to use it if you can get it up and running. Credit is due to Trader Gav who was kind enough to share in the first place. Not sure what the rules are about sharing links but I guess ill find out, is helpful for traders like me. www.tradergav.com/ I would really appreciate anyone's help on getting this fixed as I am really used to it now. Cheers |
SierraDOMcustom.cht - Attached On 2017-09-13 18:18:54 UTC - Size: 130.76 KB - 355 views |
[2017-09-14 07:42:32] |
Its seems to be working but the bids and offers are not showing. I have double checked the colouring but doesnt make a difference and when i set the graphics to default it looks like normal but still the bids and offers are missing.
[2017-09-14 08:23:56] |
NumbersBars - Posts: 141 |
Hi User745051 I had a look at your attached chartbook, DOM visible columns were not correct. You can change by clicking Trade->Customize Chart/Trade DOM Columns, and make sure the visibile columns are as below: Bid Size/Buy Column Price Ask Size/Sell Column I have double checked the DOM attached at website, it was working just fine. You can choose to download again as well. Date Time Of Last Edit: 2017-09-14 08:27:41
[2017-09-14 09:15:14] |
Thank you!!
