Date/Time: Wed, 15 Jan 2025 19:45:08 +0000
Trading multiple futures accounts with CTS / Sierra data connection?
View Count: 961
[2017-09-13 17:40:51]
Integral Trader - Posts: 33
Is it possible to trade multiple Futures trading accounts, that have the same username, through the Sierra/ CTS/ Bar Charts data/ routing connections?
My broker has setup a second trading account for me connected to T4 with the same username, however, it doesn't show up in my drop-down. I've re-booted Sierra and connected and disconnected from the data connections. I also confirmed they used the same username on the second account.
So I need your help, thanks.
[2017-09-13 18:00:06]
Is this with Wedbush? We will need reconnect to the FIX connection for this to go into effect. That will be done at the end of the day.
Also for reference here are the instructions to select an account:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SelectingTradeAccount
[2017-09-13 18:42:50]
So you will see the new account after 5:20p.m. US Eastern time.
If not, let us know.
[2017-09-14 03:51:04]
Yes this is with Wedbush.
I just checked and the account is now available on my drop down.
Thank you !
[2017-09-14 04:16:33]
Good.
