Date/Time: Wed, 15 Jan 2025 20:54:31 +0000
User Question
View Count: 928
[2017-09-13 16:31:05] |
Sierra Chart - Max - Posts: 5778 |
Hello, I keep getting messages when I run two instances of SC. One instance is using CQG data feed and the other instance is using SC "All Data Services". Please advise. Thanks, Reading Internal Order ID file. | 2017-09-13 07:09:57 Reading Trade Orders file. | 2017-09-13 07:09:57 Reading Trade Positions file. | 2017-09-13 07:09:57 Error binding to UDP port 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:09:57 Software version: 1605 | 2017-09-13 07:09:57 Usage end date: 2017-10-01 | 2017-09-13 07:09:57 Enabled for: Advanced Features. | 2017-09-13 07:09:57 Enabled for: Advanced Features 2. | 2017-09-13 07:09:57 Enabled for: Sierra Chart Historical Data Service. | 2017-09-13 07:09:57 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-09-13 07:09:57 Current selected Data/Trading service: SC Data - All Services | 2017-09-13 07:09:57 Chart Update Interval: 10 | 2017-09-13 07:09:57 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-09-13 07:09:57 2017-09-13 06:10:00 Local computer time | 2017-09-13 07:09:57 2017-09-13 11:10:00 Local computer time in UTC | 2017-09-13 07:09:57 2017-09-13 07:10:00 Local computer time in SC Time Zone | 2017-09-13 07:09:57 2017-09-13 11:10:02 Server time in UTC | 2017-09-13 07:09:57 Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-09-13 07:09:57 Program path: C:\SierraChart - Copy for EOD Analysis\ | 2017-09-13 07:09:57 Data Files path: C:\SierraChart - Copy for EOD Analysis\Data\ | 2017-09-13 07:09:57 OS Version Number: 10.0 | 2017-09-13 07:09:57 Locale Setting: C | 2017-09-13 07:09:57 Created the DTC Protocol server. | 2017-09-13 07:09:57 Listening socket (1136), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:09:57 * Listening socket (1136), port 0 | Closed. | 2017-09-13 07:09:57 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:09:57 * Created the DTC Protocol historical data server. | 2017-09-13 07:09:57 Listening socket (1092), port 0 | Failed to bind socket to 0.0.0.0:11098. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:09:57 * Listening socket (1092), port 0 | Closed. | 2017-09-13 07:09:57 HD Server Manager | Error starting listening socket on port 11098 | 2017-09-13 07:09:57 Checking for new symbol settings for service code scdataallservices | 2017-09-13 07:09:57 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-09-13 07:09:57 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-09-13 07:09:57 Received 5 login tokens. | 2017-09-13 07:09:57 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-09-13 07:10:03 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-09-13 07:10:03 SC Data - All Services | Connected to data server. | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-09-13 07:10:06 Symbol settings are up-to-date for scdataallservices | 2017-09-13 07:10:06 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-09-13 07:10:08 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event | 2017-09-13 07:10:08 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-09-13 07:10:08 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-13 07:10:08 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-09-13 07:10:08 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-09-13 07:10:11 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event | 2017-09-13 07:10:11 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-09-13 07:10:11 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-13 07:10:11 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-09-13 07:10:11 Chartbook file not found: C:\SierraChart\Data\murreymath-v1.0-test NEW.cht | 2017-09-13 07:10:13 * AUDJPY 60 Min #1 | Reloading chart. | 2017-09-13 07:10:28 AUDJPY 60 Min #2 | Reloading chart. | 2017-09-13 07:10:28 AUDJPY 60 Min #3 | Reloading chart. | 2017-09-13 07:10:28 AUDJPY 60 Min #4 | Reloading chart. | 2017-09-13 07:10:28 AUDJPY 60 Min #5 | Reloading chart. | 2017-09-13 07:10:28 AUDJPY 60 Min #6 | Reloading chart. | 2017-09-13 07:10:28 Using Bid/Ask average for last trade price for AUDJPY | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDJPY. ID: 1 | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-09-13 07:10:28 DTC Client (6) | Creating socket. | 2017-09-13 07:10:28 DTC Client (6) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Requesting security definition data for: AUDJPY. ID: 1 | 2017-09-13 07:10:28 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-09-13 07:10:28 Delaying start of download for AUDJPY | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Connected to server. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Starting socket receive thread. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Sending logon request message. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Received logon response. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Successfully connected. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Trading is not supported. | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2017-09-13 07:10:28 SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2017-09-13 07:10:28 Delaying start of download for AUDJPY | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 + Finished LoadSingleIntradayFile | 2017-09-13 07:10:29 + OnThreadComplete. | 2017-09-13 07:10:29 HD Request # 2 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-09-13 07:10:33 HD Request # 2 | Download start date-time: 2017-09-12 19:36:04.000 | 2017-09-13 07:10:33 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:10:33 Socket (7) | Creating socket. | 2017-09-13 07:10:33 Socket (7) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:10:33 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-09-13 07:10:33 HD Request # 2 | Sending historical data logon request message. | 2017-09-13 07:10:33 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-09-12 19:36:04. Record interval: 0. Symbol: AUDJPY | 2017-09-13 07:10:33 HD Request # 2 | Decompressing data. | 2017-09-13 07:10:33 HD Request # 2 | Receiving Intraday data for AUDJPY starting at 2017-09-12 19:36:04 | 2017-09-13 07:10:33 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-09-12 19:36:07 | 2017-09-13 07:10:33 Socket (7) | Initiating close of socket by core. | 2017-09-13 07:10:33 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:10:33 Socket (7) | Socket gracefully closed by remote side. | 2017-09-13 07:10:33 Socket (7) | Closed. | 2017-09-13 07:10:33 Historical data download thread signaled to stop. | 2017-09-13 07:10:33 HD Request # 2 | Received 83129 records from 2017-09-12 19:36:04 to 2017-09-13 07:10:35 (11.6 hours) and wrote 83128 records for AUDJPY | 2017-09-13 07:10:33 HD Request # 2 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 1 | 2017-09-13 07:10:33 Removed historical data download ID 1 | 2017-09-13 07:10:33 Real-time Intraday chart data file updates started for AUDJPY | 2017-09-13 07:10:33 Intraday chart data file opened for AUDJPY | 2017-09-13 07:10:33 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\AUDJPY.scid | 2017-09-13 07:10:40 AUDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:10:42 HD Request # 3 | Downloading Historical Daily chart data for AUDJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:10:42 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:10:42 Socket (8) | Creating socket. | 2017-09-13 07:10:42 Socket (8) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:10:42 Historical Daily data request for AUDJPY is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-09-13 07:10:42 Historical Daily data request for AUDJPY is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-09-13 07:10:42 Historical Daily data request for AUDJPY is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-09-13 07:10:42 Historical Daily data request for AUDJPY is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-09-13 07:10:42 Historical Daily data request for AUDJPY is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-09-13 07:10:42 HD Request # 3 | Sending historical data logon request message. | 2017-09-13 07:10:42 HD Request # 3 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:10:42 HD Request # 3 | Decompressing data. | 2017-09-13 07:10:42 HD Request # 3 | Receiving historical Daily data for AUDJPY starting at 2017-09-11 | 2017-09-13 07:10:42 HD Request # 3 | Writing historical Daily data to the file AUDJPY.dly | 2017-09-13 07:10:42 Socket (8) | Initiating close of socket by core. | 2017-09-13 07:10:42 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:10:42 Socket (8) | Socket gracefully closed by remote side. | 2017-09-13 07:10:42 Socket (8) | Closed. | 2017-09-13 07:10:42 Historical data download thread signaled to stop. | 2017-09-13 07:10:42 HD Request # 3 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for AUDJPY | 2017-09-13 07:10:42 HD Request # 3 | Daily download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 2 | 2017-09-13 07:10:42 Removed historical data download ID 2 | 2017-09-13 07:10:42 AUDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:10:42 AUDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 + OnThreadComplete. | 2017-09-13 07:10:42 AUDNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:10:56 Using Bid/Ask average for last trade price for AUDNZD | 2017-09-13 07:10:56 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDNZD. ID: 2 | 2017-09-13 07:10:56 SC DTC Data with Market Depth | Requesting security definition data for: AUDNZD. ID: 2 | 2017-09-13 07:10:56 HD Request # 4 | Downloading Historical Daily chart data for AUDNZD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:10:56 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:10:56 Socket (9) | Creating socket. | 2017-09-13 07:10:56 Socket (9) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 AUDNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 AUDNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-09-13 07:10:56 HD Request # 4 | Sending historical data logon request message. | 2017-09-13 07:10:56 HD Request # 4 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:10:56 HD Request # 4 | Decompressing data. | 2017-09-13 07:10:56 HD Request # 4 | Receiving historical Daily data for AUDNZD starting at 2017-09-11 | 2017-09-13 07:10:56 HD Request # 4 | Writing historical Daily data to the file AUDNZD.dly | 2017-09-13 07:10:56 Socket (9) | Initiating close of socket by core. | 2017-09-13 07:10:56 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:10:56 Socket (9) | Socket gracefully closed by remote side. | 2017-09-13 07:10:56 Socket (9) | Closed. | 2017-09-13 07:10:56 Historical data download thread signaled to stop. | 2017-09-13 07:10:56 HD Request # 4 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for AUDNZD | 2017-09-13 07:10:56 HD Request # 4 | Daily download COMPLETE for AUDNZD. Completion time: 0s. Unique request ID: 8 | 2017-09-13 07:10:56 Removed historical data download ID 8 | 2017-09-13 07:10:56 AUDNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:10:56 AUDNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 + OnThreadComplete. | 2017-09-13 07:10:56 Listening socket (1232), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:11:00 * Listening socket (1232), port 0 | Closed. | 2017-09-13 07:11:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:11:00 * AUDNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:06 AUDNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:06 AUDNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:06 + OnThreadComplete. | 2017-09-13 07:11:06 + OnThreadComplete. | 2017-09-13 07:11:06 + OnThreadComplete. | 2017-09-13 07:11:06 AUDNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:06 AUDNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:06 + OnThreadComplete. | 2017-09-13 07:11:06 + OnThreadComplete. | 2017-09-13 07:11:06 AUDUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:09 Using Bid/Ask average for last trade price for AUDUSD | 2017-09-13 07:11:09 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 3 | 2017-09-13 07:11:09 SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 3 | 2017-09-13 07:11:09 HD Request # 5 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:09 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:11:09 Socket (10) | Creating socket. | 2017-09-13 07:11:09 Socket (10) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:09 HD Request # 5 | Sending historical data logon request message. | 2017-09-13 07:11:09 HD Request # 5 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:09 HD Request # 5 | Decompressing data. | 2017-09-13 07:11:09 HD Request # 5 | Receiving historical Daily data for AUDUSD starting at 2017-09-11 | 2017-09-13 07:11:09 HD Request # 5 | Writing historical Daily data to the file AUDUSD.dly | 2017-09-13 07:11:09 Socket (10) | Initiating close of socket by core. | 2017-09-13 07:11:09 Socket (10) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:09 Socket (10) | Socket gracefully closed by remote side. | 2017-09-13 07:11:09 Socket (10) | Closed. | 2017-09-13 07:11:09 Historical data download thread signaled to stop. | 2017-09-13 07:11:09 HD Request # 5 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for AUDUSD | 2017-09-13 07:11:09 HD Request # 5 | Daily download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 9 | 2017-09-13 07:11:09 Removed historical data download ID 9 | 2017-09-13 07:11:09 AUDUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:09 AUDUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 + OnThreadComplete. | 2017-09-13 07:11:09 CADJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:15 Using Bid/Ask average for last trade price for CADJPY | 2017-09-13 07:11:15 SC DTC Data with Market Depth | Starting real-time market data updates for: CADJPY. ID: 4 | 2017-09-13 07:11:15 SC DTC Data with Market Depth | Requesting security definition data for: CADJPY. ID: 4 | 2017-09-13 07:11:15 HD Request # 6 | Downloading Historical Daily chart data for CADJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:15 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:11:15 Socket (11) | Creating socket. | 2017-09-13 07:11:15 Socket (11) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 SC DTC Data with Market Depth | Received security definition for symbol CADJPY | 2017-09-13 07:11:15 HD Request # 6 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:15 HD Request # 6 | Sending historical data logon request message. | 2017-09-13 07:11:15 HD Request # 6 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:15 HD Request # 6 | Decompressing data. | 2017-09-13 07:11:15 HD Request # 6 | Receiving historical Daily data for CADJPY starting at 2017-09-11 | 2017-09-13 07:11:15 HD Request # 6 | Writing historical Daily data to the file CADJPY.dly | 2017-09-13 07:11:15 Socket (11) | Initiating close of socket by core. | 2017-09-13 07:11:15 Socket (11) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:15 Socket (11) | Socket gracefully closed by remote side. | 2017-09-13 07:11:15 Socket (11) | Closed. | 2017-09-13 07:11:15 Historical data download thread signaled to stop. | 2017-09-13 07:11:15 HD Request # 6 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for CADJPY | 2017-09-13 07:11:15 HD Request # 6 | Daily download COMPLETE for CADJPY. Completion time: 0s. Unique request ID: 10 | 2017-09-13 07:11:15 Removed historical data download ID 10 | 2017-09-13 07:11:15 CADJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:15 CADJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 + OnThreadComplete. | 2017-09-13 07:11:15 EURCAD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:17 Using Bid/Ask average for last trade price for EURCAD | 2017-09-13 07:11:17 SC DTC Data with Market Depth | Starting real-time market data updates for: EURCAD. ID: 5 | 2017-09-13 07:11:17 SC DTC Data with Market Depth | Requesting security definition data for: EURCAD. ID: 5 | 2017-09-13 07:11:17 HD Request # 7 | Downloading Historical Daily chart data for EURCAD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:17 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:11:17 Socket (12) | Creating socket. | 2017-09-13 07:11:17 Socket (12) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 SC DTC Data with Market Depth | Received security definition for symbol EURCAD | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 HD Request # 7 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:17 HD Request # 7 | Sending historical data logon request message. | 2017-09-13 07:11:17 HD Request # 7 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:17 HD Request # 7 | Decompressing data. | 2017-09-13 07:11:17 HD Request # 7 | Receiving historical Daily data for EURCAD starting at 2017-09-11 | 2017-09-13 07:11:17 HD Request # 7 | Writing historical Daily data to the file EURCAD.dly | 2017-09-13 07:11:17 Socket (12) | Initiating close of socket by core. | 2017-09-13 07:11:17 Socket (12) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:17 Socket (12) | Socket gracefully closed by remote side. | 2017-09-13 07:11:17 Socket (12) | Closed. | 2017-09-13 07:11:17 Historical data download thread signaled to stop. | 2017-09-13 07:11:17 HD Request # 7 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURCAD | 2017-09-13 07:11:17 HD Request # 7 | Daily download COMPLETE for EURCAD. Completion time: 0s. Unique request ID: 11 | 2017-09-13 07:11:17 Removed historical data download ID 11 | 2017-09-13 07:11:17 EURCAD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:17 EURCAD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 + OnThreadComplete. | 2017-09-13 07:11:17 EURCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:19 Using Bid/Ask average for last trade price for EURCHF | 2017-09-13 07:11:19 SC DTC Data with Market Depth | Starting real-time market data updates for: EURCHF. ID: 6 | 2017-09-13 07:11:19 SC DTC Data with Market Depth | Requesting security definition data for: EURCHF. ID: 6 | 2017-09-13 07:11:19 HD Request # 8 | Downloading Historical Daily chart data for EURCHF. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:19 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:11:19 Socket (13) | Creating socket. | 2017-09-13 07:11:19 Socket (13) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 EURCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:19 EURCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:19 EURCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:19 EURCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:19 SC DTC Data with Market Depth | Received security definition for symbol EURCHF | 2017-09-13 07:11:19 EURCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:19 HD Request # 8 | Sending historical data logon request message. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 + OnThreadComplete. | 2017-09-13 07:11:19 HD Request # 8 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:19 HD Request # 8 | Decompressing data. | 2017-09-13 07:11:19 HD Request # 8 | Receiving historical Daily data for EURCHF starting at 2017-09-11 | 2017-09-13 07:11:19 HD Request # 8 | Writing historical Daily data to the file EURCHF.dly | 2017-09-13 07:11:19 Socket (13) | Initiating close of socket by core. | 2017-09-13 07:11:20 Socket (13) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:20 Socket (13) | Socket gracefully closed by remote side. | 2017-09-13 07:11:20 Socket (13) | Closed. | 2017-09-13 07:11:20 Historical data download thread signaled to stop. | 2017-09-13 07:11:20 HD Request # 8 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURCHF | 2017-09-13 07:11:20 HD Request # 8 | Daily download COMPLETE for EURCHF. Completion time: 0s. Unique request ID: 12 | 2017-09-13 07:11:20 Removed historical data download ID 12 | 2017-09-13 07:11:20 EURCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:20 EURCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:20 EURCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:20 EURCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:20 EURCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:20 EURCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 + OnThreadComplete. | 2017-09-13 07:11:20 EURGBP [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:21 Using Bid/Ask average for last trade price for EURGBP | 2017-09-13 07:11:21 SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 7 | 2017-09-13 07:11:21 SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 7 | 2017-09-13 07:11:21 HD Request # 9 | Downloading Historical Daily chart data for EURGBP. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:21 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:11:21 Socket (14) | Creating socket. | 2017-09-13 07:11:21 Socket (14) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:11:21 EURGBP [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:21 EURGBP [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:21 + OnThreadComplete. | 2017-09-13 07:11:21 EURGBP [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:21 EURGBP [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:21 SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2017-09-13 07:11:21 EURGBP [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:21 HD Request # 9 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:22 HD Request # 9 | Sending historical data logon request message. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 HD Request # 9 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:22 HD Request # 9 | Decompressing data. | 2017-09-13 07:11:22 HD Request # 9 | Receiving historical Daily data for EURGBP starting at 2017-09-11 | 2017-09-13 07:11:22 HD Request # 9 | Writing historical Daily data to the file EURGBP.dly | 2017-09-13 07:11:22 Socket (14) | Initiating close of socket by core. | 2017-09-13 07:11:22 Socket (14) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:22 Socket (14) | Socket gracefully closed by remote side. | 2017-09-13 07:11:22 Socket (14) | Closed. | 2017-09-13 07:11:22 Historical data download thread signaled to stop. | 2017-09-13 07:11:22 HD Request # 9 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURGBP | 2017-09-13 07:11:22 HD Request # 9 | Daily download COMPLETE for EURGBP. Completion time: 1s. Unique request ID: 13 | 2017-09-13 07:11:22 Removed historical data download ID 13 | 2017-09-13 07:11:22 EURGBP [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:22 EURGBP [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:22 EURGBP [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:22 EURGBP [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:22 EURGBP [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:22 EURGBP [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 + OnThreadComplete. | 2017-09-13 07:11:22 EURJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:26 Using Bid/Ask average for last trade price for EURJPY | 2017-09-13 07:11:26 SC DTC Data with Market Depth | Starting real-time market data updates for: EURJPY. ID: 8 | 2017-09-13 07:11:26 SC DTC Data with Market Depth | Requesting security definition data for: EURJPY. ID: 8 | 2017-09-13 07:11:26 HD Request # 10 | Downloading Historical Daily chart data for EURJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:26 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:11:26 Socket (15) | Creating socket. | 2017-09-13 07:11:26 Socket (15) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:11:26 EURJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:26 SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2017-09-13 07:11:26 EURJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 EURJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:26 HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:26 HD Request # 10 | Sending historical data logon request message. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 HD Request # 10 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:26 HD Request # 10 | Decompressing data. | 2017-09-13 07:11:26 HD Request # 10 | Receiving historical Daily data for EURJPY starting at 2017-09-11 | 2017-09-13 07:11:26 HD Request # 10 | Writing historical Daily data to the file EURJPY.dly | 2017-09-13 07:11:26 Socket (15) | Initiating close of socket by core. | 2017-09-13 07:11:26 Socket (15) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:26 Socket (15) | Socket gracefully closed by remote side. | 2017-09-13 07:11:26 Socket (15) | Closed. | 2017-09-13 07:11:26 Historical data download thread signaled to stop. | 2017-09-13 07:11:26 HD Request # 10 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURJPY | 2017-09-13 07:11:26 HD Request # 10 | Daily download COMPLETE for EURJPY. Completion time: 0s. Unique request ID: 14 | 2017-09-13 07:11:26 Removed historical data download ID 14 | 2017-09-13 07:11:26 EURJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:26 EURJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 + OnThreadComplete. | 2017-09-13 07:11:26 EURNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:28 Using Bid/Ask average for last trade price for EURNZD | 2017-09-13 07:11:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURNZD. ID: 9 | 2017-09-13 07:11:28 SC DTC Data with Market Depth | Requesting security definition data for: EURNZD. ID: 9 | 2017-09-13 07:11:28 HD Request # 11 | Downloading Historical Daily chart data for EURNZD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:28 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:11:28 Socket (16) | Creating socket. | 2017-09-13 07:11:28 Socket (16) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 SC DTC Data with Market Depth | Received security definition for symbol EURNZD | 2017-09-13 07:11:28 HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:28 HD Request # 11 | Sending historical data logon request message. | 2017-09-13 07:11:28 HD Request # 11 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:28 HD Request # 11 | Decompressing data. | 2017-09-13 07:11:28 HD Request # 11 | Receiving historical Daily data for EURNZD starting at 2017-09-11 | 2017-09-13 07:11:28 HD Request # 11 | Writing historical Daily data to the file EURNZD.dly | 2017-09-13 07:11:28 Socket (16) | Initiating close of socket by core. | 2017-09-13 07:11:28 Socket (16) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:28 Socket (16) | Socket gracefully closed by remote side. | 2017-09-13 07:11:28 Socket (16) | Closed. | 2017-09-13 07:11:28 Historical data download thread signaled to stop. | 2017-09-13 07:11:28 HD Request # 11 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURNZD | 2017-09-13 07:11:28 HD Request # 11 | Daily download COMPLETE for EURNZD. Completion time: 0s. Unique request ID: 15 | 2017-09-13 07:11:28 Removed historical data download ID 15 | 2017-09-13 07:11:28 EURNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:28 EURNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 + OnThreadComplete. | 2017-09-13 07:11:28 EURUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:30 Using Bid/Ask average for last trade price for EURUSD | 2017-09-13 07:11:30 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 10 | 2017-09-13 07:11:30 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 10 | 2017-09-13 07:11:30 HD Request # 12 | Downloading Historical Daily chart data for EURUSD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:30 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:11:30 Socket (17) | Creating socket. | 2017-09-13 07:11:30 Socket (17) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:30 HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:30 HD Request # 12 | Sending historical data logon request message. | 2017-09-13 07:11:30 HD Request # 12 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:30 HD Request # 12 | Decompressing data. | 2017-09-13 07:11:30 HD Request # 12 | Receiving historical Daily data for EURUSD starting at 2017-09-11 | 2017-09-13 07:11:30 HD Request # 12 | Writing historical Daily data to the file EURUSD.dly | 2017-09-13 07:11:30 Socket (17) | Initiating close of socket by core. | 2017-09-13 07:11:30 Socket (17) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:30 Socket (17) | Socket gracefully closed by remote side. | 2017-09-13 07:11:30 Socket (17) | Closed. | 2017-09-13 07:11:30 Historical data download thread signaled to stop. | 2017-09-13 07:11:30 HD Request # 12 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for EURUSD | 2017-09-13 07:11:30 HD Request # 12 | Daily download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 16 | 2017-09-13 07:11:30 Removed historical data download ID 16 | 2017-09-13 07:11:30 EURUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:30 EURUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:30 + OnThreadComplete. | 2017-09-13 07:11:31 + OnThreadComplete. | 2017-09-13 07:11:31 + OnThreadComplete. | 2017-09-13 07:11:31 + OnThreadComplete. | 2017-09-13 07:11:31 + OnThreadComplete. | 2017-09-13 07:11:31 + OnThreadComplete. | 2017-09-13 07:11:31 EURNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:32 EURNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:32 EURNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:32 EURNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:32 EURNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:32 EURNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 + OnThreadComplete. | 2017-09-13 07:11:32 EURUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:40 EURUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:40 EURUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:40 EURUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:40 EURUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:40 EURUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 + OnThreadComplete. | 2017-09-13 07:11:40 EURNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:42 EURNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:42 EURNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:42 EURNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:42 EURNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:42 EURNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 + OnThreadComplete. | 2017-09-13 07:11:42 EURUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:45 EURUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:45 EURUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:45 EURUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:45 EURUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:45 EURUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:45 + OnThreadComplete. | 2017-09-13 07:11:46 GBPAUD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:51 GBPAUD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:51 GBPAUD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:51 GBPAUD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:51 GBPAUD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:51 GBPAUD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:51 Using Bid/Ask average for last trade price for GBPAUD | 2017-09-13 07:11:51 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPAUD. ID: 11 | 2017-09-13 07:11:51 SC DTC Data with Market Depth | Requesting security definition data for: GBPAUD. ID: 11 | 2017-09-13 07:11:51 HD Request # 13 | Downloading Historical Daily chart data for GBPAUD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:51 HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:11:51 Socket (18) | Creating socket. | 2017-09-13 07:11:51 Socket (18) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 + OnThreadComplete. | 2017-09-13 07:11:51 SC DTC Data with Market Depth | Received security definition for symbol GBPAUD | 2017-09-13 07:11:51 HD Request # 13 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:52 HD Request # 13 | Sending historical data logon request message. | 2017-09-13 07:11:52 HD Request # 13 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:52 HD Request # 13 | Decompressing data. | 2017-09-13 07:11:52 HD Request # 13 | Receiving historical Daily data for GBPAUD starting at 2017-09-11 | 2017-09-13 07:11:52 HD Request # 13 | Writing historical Daily data to the file GBPAUD.dly | 2017-09-13 07:11:52 Socket (18) | Initiating close of socket by core. | 2017-09-13 07:11:52 Socket (18) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:52 Socket (18) | Socket gracefully closed by remote side. | 2017-09-13 07:11:52 Socket (18) | Closed. | 2017-09-13 07:11:52 Historical data download thread signaled to stop. | 2017-09-13 07:11:52 HD Request # 13 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for GBPAUD | 2017-09-13 07:11:52 HD Request # 13 | Daily download COMPLETE for GBPAUD. Completion time: 1s. Unique request ID: 17 | 2017-09-13 07:11:52 Removed historical data download ID 17 | 2017-09-13 07:11:52 GBPAUD [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:52 GBPAUD [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:52 GBPAUD [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:52 GBPAUD [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:52 GBPAUD [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:52 GBPAUD [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 + OnThreadComplete. | 2017-09-13 07:11:52 GBPCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:55 GBPCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:55 GBPCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:55 GBPCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:55 GBPCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:55 GBPCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 Using Bid/Ask average for last trade price for GBPCHF | 2017-09-13 07:11:55 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCHF. ID: 12 | 2017-09-13 07:11:55 SC DTC Data with Market Depth | Requesting security definition data for: GBPCHF. ID: 12 | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 HD Request # 14 | Downloading Historical Daily chart data for GBPCHF. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:11:55 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:11:55 Socket (19) | Creating socket. | 2017-09-13 07:11:55 Socket (19) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 + OnThreadComplete. | 2017-09-13 07:11:55 SC DTC Data with Market Depth | Received security definition for symbol GBPCHF | 2017-09-13 07:11:55 HD Request # 14 | Setting DTC encoding to Binary VLS | 2017-09-13 07:11:56 HD Request # 14 | Sending historical data logon request message. | 2017-09-13 07:11:56 HD Request # 14 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:11:56 HD Request # 14 | Decompressing data. | 2017-09-13 07:11:56 HD Request # 14 | Receiving historical Daily data for GBPCHF starting at 2017-09-11 | 2017-09-13 07:11:56 HD Request # 14 | Writing historical Daily data to the file GBPCHF.dly | 2017-09-13 07:11:56 Socket (19) | Initiating close of socket by core. | 2017-09-13 07:11:56 Socket (19) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:11:56 Socket (19) | Socket gracefully closed by remote side. | 2017-09-13 07:11:56 Socket (19) | Closed. | 2017-09-13 07:11:56 Historical data download thread signaled to stop. | 2017-09-13 07:11:56 HD Request # 14 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for GBPCHF | 2017-09-13 07:11:56 HD Request # 14 | Daily download COMPLETE for GBPCHF. Completion time: 0s. Unique request ID: 18 | 2017-09-13 07:11:56 Removed historical data download ID 18 | 2017-09-13 07:11:56 GBPCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:11:56 GBPCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:11:56 GBPCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:11:56 GBPCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:11:56 GBPCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 GBPCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 + OnThreadComplete. | 2017-09-13 07:11:56 GBPJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:00 Using Bid/Ask average for last trade price for GBPJPY | 2017-09-13 07:12:00 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPJPY. ID: 13 | 2017-09-13 07:12:00 SC DTC Data with Market Depth | Requesting security definition data for: GBPJPY. ID: 13 | 2017-09-13 07:12:00 HD Request # 15 | Downloading Historical Daily chart data for GBPJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:00 HD Request # 15 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:12:00 Socket (20) | Creating socket. | 2017-09-13 07:12:00 Socket (20) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:12:00 GBPJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:00 SC DTC Data with Market Depth | Received security definition for symbol GBPJPY | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 HD Request # 15 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:00 HD Request # 15 | Sending historical data logon request message. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 HD Request # 15 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:00 HD Request # 15 | Decompressing data. | 2017-09-13 07:12:00 HD Request # 15 | Receiving historical Daily data for GBPJPY starting at 2017-09-11 | 2017-09-13 07:12:00 HD Request # 15 | Writing historical Daily data to the file GBPJPY.dly | 2017-09-13 07:12:00 Socket (20) | Initiating close of socket by core. | 2017-09-13 07:12:00 Socket (20) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:00 Socket (20) | Socket gracefully closed by remote side. | 2017-09-13 07:12:00 Socket (20) | Closed. | 2017-09-13 07:12:00 Historical data download thread signaled to stop. | 2017-09-13 07:12:00 HD Request # 15 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for GBPJPY | 2017-09-13 07:12:00 HD Request # 15 | Daily download COMPLETE for GBPJPY. Completion time: 0s. Unique request ID: 19 | 2017-09-13 07:12:00 Removed historical data download ID 19 | 2017-09-13 07:12:00 GBPJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:00 GBPJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 + OnThreadComplete. | 2017-09-13 07:12:00 Listening socket (1908), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:12:00 * Listening socket (1908), port 0 | Closed. | 2017-09-13 07:12:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:12:00 * GBPJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:10 GBPJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:10 GBPJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:10 GBPJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:10 GBPJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:10 + OnThreadComplete. | 2017-09-13 07:12:10 + OnThreadComplete. | 2017-09-13 07:12:10 + OnThreadComplete. | 2017-09-13 07:12:10 + OnThreadComplete. | 2017-09-13 07:12:10 + OnThreadComplete. | 2017-09-13 07:12:10 GBPNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 GBPNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 GBPNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 Using Bid/Ask average for last trade price for GBPNZD | 2017-09-13 07:12:15 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPNZD. ID: 14 | 2017-09-13 07:12:15 SC DTC Data with Market Depth | Requesting security definition data for: GBPNZD. ID: 14 | 2017-09-13 07:12:15 HD Request # 16 | Downloading Historical Daily chart data for GBPNZD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:15 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:12:15 Socket (21) | Creating socket. | 2017-09-13 07:12:15 Socket (21) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:12:15 SC DTC Data with Market Depth | Received security definition for symbol GBPNZD | 2017-09-13 07:12:15 HD Request # 16 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:15 HD Request # 16 | Sending historical data logon request message. | 2017-09-13 07:12:15 HD Request # 16 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:15 HD Request # 16 | Decompressing data. | 2017-09-13 07:12:15 HD Request # 16 | Receiving historical Daily data for GBPNZD starting at 2017-09-11 | 2017-09-13 07:12:15 HD Request # 16 | Writing historical Daily data to the file GBPNZD.dly | 2017-09-13 07:12:15 Socket (21) | Initiating close of socket by core. | 2017-09-13 07:12:15 Socket (21) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:15 Socket (21) | Socket gracefully closed by remote side. | 2017-09-13 07:12:15 Socket (21) | Closed. | 2017-09-13 07:12:15 Historical data download thread signaled to stop. | 2017-09-13 07:12:15 HD Request # 16 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for GBPNZD | 2017-09-13 07:12:15 HD Request # 16 | Daily download COMPLETE for GBPNZD. Completion time: 0s. Unique request ID: 20 | 2017-09-13 07:12:15 Removed historical data download ID 20 | 2017-09-13 07:12:15 GBPNZD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:15 GBPNZD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 GBPNZD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 GBPNZD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:15 + OnThreadComplete. | 2017-09-13 07:12:15 GBPUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:24 Using Bid/Ask average for last trade price for GBPUSD | 2017-09-13 07:12:24 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 15 | 2017-09-13 07:12:24 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 15 | 2017-09-13 07:12:24 HD Request # 17 | Downloading Historical Daily chart data for GBPUSD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:24 HD Request # 17 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:12:24 Socket (22) | Creating socket. | 2017-09-13 07:12:24 Socket (22) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:12:24 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 HD Request # 17 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:24 HD Request # 17 | Sending historical data logon request message. | 2017-09-13 07:12:24 HD Request # 17 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:24 HD Request # 17 | Decompressing data. | 2017-09-13 07:12:24 HD Request # 17 | Receiving historical Daily data for GBPUSD starting at 2017-09-11 | 2017-09-13 07:12:24 HD Request # 17 | Writing historical Daily data to the file GBPUSD.dly | 2017-09-13 07:12:24 Socket (22) | Initiating close of socket by core. | 2017-09-13 07:12:24 Socket (22) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:24 Socket (22) | Socket gracefully closed by remote side. | 2017-09-13 07:12:24 Socket (22) | Closed. | 2017-09-13 07:12:24 Historical data download thread signaled to stop. | 2017-09-13 07:12:24 HD Request # 17 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for GBPUSD | 2017-09-13 07:12:24 HD Request # 17 | Daily download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 21 | 2017-09-13 07:12:24 Removed historical data download ID 21 | 2017-09-13 07:12:24 GBPUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:24 GBPUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 + OnThreadComplete. | 2017-09-13 07:12:24 GBPUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:34 GBPUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:34 GBPUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:34 + OnThreadComplete. | 2017-09-13 07:12:34 GBPUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:34 GBPUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:34 + OnThreadComplete. | 2017-09-13 07:12:34 + OnThreadComplete. | 2017-09-13 07:12:34 + OnThreadComplete. | 2017-09-13 07:12:34 + OnThreadComplete. | 2017-09-13 07:12:34 NZDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:40 Using Bid/Ask average for last trade price for NZDJPY | 2017-09-13 07:12:40 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDJPY. ID: 16 | 2017-09-13 07:12:40 SC DTC Data with Market Depth | Requesting security definition data for: NZDJPY. ID: 16 | 2017-09-13 07:12:40 HD Request # 18 | Downloading Historical Daily chart data for NZDJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:40 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:12:40 Socket (23) | Creating socket. | 2017-09-13 07:12:40 Socket (23) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:12:40 NZDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 NZDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:40 SC DTC Data with Market Depth | Received security definition for symbol NZDJPY | 2017-09-13 07:12:40 NZDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 HD Request # 18 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:40 HD Request # 18 | Sending historical data logon request message. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 HD Request # 18 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:40 HD Request # 18 | Decompressing data. | 2017-09-13 07:12:40 HD Request # 18 | Receiving historical Daily data for NZDJPY starting at 2017-09-11 | 2017-09-13 07:12:40 HD Request # 18 | Writing historical Daily data to the file NZDJPY.dly | 2017-09-13 07:12:40 Socket (23) | Initiating close of socket by core. | 2017-09-13 07:12:40 Socket (23) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:40 Socket (23) | Socket gracefully closed by remote side. | 2017-09-13 07:12:40 Socket (23) | Closed. | 2017-09-13 07:12:40 Historical data download thread signaled to stop. | 2017-09-13 07:12:40 HD Request # 18 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for NZDJPY | 2017-09-13 07:12:40 HD Request # 18 | Daily download COMPLETE for NZDJPY. Completion time: 1s. Unique request ID: 22 | 2017-09-13 07:12:40 Removed historical data download ID 22 | 2017-09-13 07:12:40 NZDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:40 NZDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 + OnThreadComplete. | 2017-09-13 07:12:40 NZDUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:42 Using Bid/Ask average for last trade price for NZDUSD | 2017-09-13 07:12:42 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDUSD. ID: 17 | 2017-09-13 07:12:42 SC DTC Data with Market Depth | Requesting security definition data for: NZDUSD. ID: 17 | 2017-09-13 07:12:42 HD Request # 19 | Downloading Historical Daily chart data for NZDUSD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:42 HD Request # 19 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:12:42 Socket (24) | Creating socket. | 2017-09-13 07:12:42 Socket (24) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 SC DTC Data with Market Depth | Received security definition for symbol NZDUSD | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 HD Request # 19 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:42 HD Request # 19 | Sending historical data logon request message. | 2017-09-13 07:12:42 HD Request # 19 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:42 HD Request # 19 | Decompressing data. | 2017-09-13 07:12:42 HD Request # 19 | Receiving historical Daily data for NZDUSD starting at 2017-09-11 | 2017-09-13 07:12:42 HD Request # 19 | Writing historical Daily data to the file NZDUSD.dly | 2017-09-13 07:12:42 Socket (24) | Initiating close of socket by core. | 2017-09-13 07:12:42 Socket (24) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:42 Socket (24) | Socket gracefully closed by remote side. | 2017-09-13 07:12:42 Socket (24) | Closed. | 2017-09-13 07:12:42 Historical data download thread signaled to stop. | 2017-09-13 07:12:42 HD Request # 19 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for NZDUSD | 2017-09-13 07:12:42 HD Request # 19 | Daily download COMPLETE for NZDUSD. Completion time: 0s. Unique request ID: 23 | 2017-09-13 07:12:42 Removed historical data download ID 23 | 2017-09-13 07:12:42 NZDUSD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:42 NZDUSD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 + OnThreadComplete. | 2017-09-13 07:12:42 USDCAD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:44 USDCAD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:44 USDCAD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:44 USDCAD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:44 USDCAD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 USDCAD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:44 Using Bid/Ask average for last trade price for USDCAD | 2017-09-13 07:12:44 SC DTC Data with Market Depth | Starting real-time market data updates for: USDCAD. ID: 18 | 2017-09-13 07:12:44 SC DTC Data with Market Depth | Requesting security definition data for: USDCAD. ID: 18 | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 HD Request # 20 | Downloading Historical Daily chart data for USDCAD. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:44 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:12:44 Socket (25) | Creating socket. | 2017-09-13 07:12:44 Socket (25) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 + OnThreadComplete. | 2017-09-13 07:12:44 SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2017-09-13 07:12:44 HD Request # 20 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:44 HD Request # 20 | Sending historical data logon request message. | 2017-09-13 07:12:44 HD Request # 20 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:45 HD Request # 20 | Decompressing data. | 2017-09-13 07:12:45 HD Request # 20 | Receiving historical Daily data for USDCAD starting at 2017-09-11 | 2017-09-13 07:12:45 HD Request # 20 | Writing historical Daily data to the file USDCAD.dly | 2017-09-13 07:12:45 Socket (25) | Initiating close of socket by core. | 2017-09-13 07:12:45 Socket (25) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:45 Socket (25) | Socket gracefully closed by remote side. | 2017-09-13 07:12:45 Socket (25) | Closed. | 2017-09-13 07:12:45 Historical data download thread signaled to stop. | 2017-09-13 07:12:45 HD Request # 20 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for USDCAD | 2017-09-13 07:12:45 HD Request # 20 | Daily download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 24 | 2017-09-13 07:12:45 Removed historical data download ID 24 | 2017-09-13 07:12:45 USDCAD [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:45 USDCAD [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:45 USDCAD [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:45 USDCAD [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:45 USDCAD [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 USDCAD [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 + OnThreadComplete. | 2017-09-13 07:12:45 USDCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:52 USDCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:52 USDCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:52 USDCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:52 USDCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:52 USDCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:52 Using Bid/Ask average for last trade price for USDCHF | 2017-09-13 07:12:52 SC DTC Data with Market Depth | Starting real-time market data updates for: USDCHF. ID: 19 | 2017-09-13 07:12:52 SC DTC Data with Market Depth | Requesting security definition data for: USDCHF. ID: 19 | 2017-09-13 07:12:52 HD Request # 21 | Downloading Historical Daily chart data for USDCHF. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:52 HD Request # 21 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:12:52 Socket (26) | Creating socket. | 2017-09-13 07:12:52 Socket (26) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:12:52 SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 HD Request # 21 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:53 HD Request # 21 | Sending historical data logon request message. | 2017-09-13 07:12:53 HD Request # 21 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:53 HD Request # 21 | Decompressing data. | 2017-09-13 07:12:53 HD Request # 21 | Receiving historical Daily data for USDCHF starting at 2017-09-11 | 2017-09-13 07:12:53 HD Request # 21 | Writing historical Daily data to the file USDCHF.dly | 2017-09-13 07:12:53 Socket (26) | Initiating close of socket by core. | 2017-09-13 07:12:53 Socket (26) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:53 Socket (26) | Socket gracefully closed by remote side. | 2017-09-13 07:12:53 Socket (26) | Closed. | 2017-09-13 07:12:53 Historical data download thread signaled to stop. | 2017-09-13 07:12:53 HD Request # 21 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for USDCHF | 2017-09-13 07:12:53 HD Request # 21 | Daily download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 25 | 2017-09-13 07:12:53 Removed historical data download ID 25 | 2017-09-13 07:12:53 USDCHF [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:53 USDCHF [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:53 USDCHF [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:53 USDCHF [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:53 USDCHF [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:53 USDCHF [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 + OnThreadComplete. | 2017-09-13 07:12:53 USDHUF [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:56 SC Data - All Services | Starting real-time market data updates for: USDHUF. ID: 20 | 2017-09-13 07:12:56 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: USDHUF | 2017-09-13 07:12:56 SC Data - All Services | Requesting security definition data for: USDHUF. ID: 20 | 2017-09-13 07:12:56 HD Request # 22 | Downloading Historical Daily chart data for USDHUF. Starting date: 2017-09-11. Service: scdataallservices | 2017-09-13 07:12:56 Historical data download counter reset. | 2017-09-13 07:12:56 HD Request # 22 | Requesting historical Daily data for ^USDHUF starting at 2017-09-10 | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 USDHUF [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:56 USDHUF [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:56 USDHUF [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:56 USDHUF [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:56 USDHUF [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 USDJPY Daily #3 | Reloading chart. | 2017-09-13 07:12:56 Using Bid/Ask average for last trade price for USDJPY | 2017-09-13 07:12:56 SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 21 | 2017-09-13 07:12:56 SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 21 | 2017-09-13 07:12:56 HD Request # 23 | Downloading Historical Daily chart data for USDJPY. Starting date: 2017-09-11. Service: fxcm | 2017-09-13 07:12:56 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 HTTP connection to ds01.ddfplus.com:80 (27) | Creating socket. | 2017-09-13 07:12:56 HTTP connection to ds01.ddfplus.com:80 (27) | Connecting to IP: 8.18.161.123. | 2017-09-13 07:12:56 Socket (28) | Creating socket. | 2017-09-13 07:12:56 Socket (28) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:12:56 USDJPY Daily #2 | Reloading chart. | 2017-09-13 07:12:56 USDJPY Daily #1 | Reloading chart. | 2017-09-13 07:12:56 USDJPY Daily #4 | Reloading chart. | 2017-09-13 07:12:56 USDJPY Daily #5 | Reloading chart. | 2017-09-13 07:12:56 SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2017-09-13 07:12:56 USDJPY Daily #6 | Reloading chart. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 + OnThreadComplete. | 2017-09-13 07:12:56 HD Request # 22 | Receiving historical Daily data for USDHUF starting at 2017-09-11 | 2017-09-13 07:12:56 HD Request # 22 | Writing historical Daily data to the file USDHUF.dly | 2017-09-13 07:12:56 HD Request # 23 | Setting DTC encoding to Binary VLS | 2017-09-13 07:12:56 HD Request # 23 | Sending historical data logon request message. | 2017-09-13 07:12:56 HD Request # 22 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for USDHUF | 2017-09-13 07:12:56 HD Request # 22 | Daily download COMPLETE for USDHUF. Completion time: 0s. Unique request ID: 26 | 2017-09-13 07:12:56 Removed historical data download ID 26 | 2017-09-13 07:12:56 HD Request # 23 | Requesting historical Daily data starting at 2017-09-11. | 2017-09-13 07:12:56 HD Request # 23 | Decompressing data. | 2017-09-13 07:12:57 HD Request # 23 | Receiving historical Daily data for USDJPY starting at 2017-09-11 | 2017-09-13 07:12:57 HD Request # 23 | Writing historical Daily data to the file USDJPY.dly | 2017-09-13 07:12:57 Socket (28) | Initiating close of socket by core. | 2017-09-13 07:12:57 Socket (28) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:12:57 Socket (28) | Socket gracefully closed by remote side. | 2017-09-13 07:12:57 Socket (28) | Closed. | 2017-09-13 07:12:57 Historical data download thread signaled to stop. | 2017-09-13 07:12:57 HD Request # 23 | Received 3 records from 2017-09-11 00:00:00 to 2017-09-13 00:00:00 (3.0 days) and wrote 3 records for USDJPY | 2017-09-13 07:12:57 HD Request # 23 | Daily download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 27 | 2017-09-13 07:12:57 Removed historical data download ID 27 | 2017-09-13 07:12:57 USDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:12:57 USDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:12:57 USDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:12:57 USDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:12:57 USDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:12:57 USDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 + OnThreadComplete. | 2017-09-13 07:12:57 Listening socket (1192), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:13:00 * Listening socket (1192), port 0 | Closed. | 2017-09-13 07:13:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:13:00 * USDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:13:06 USDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:13:06 USDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:13:06 USDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:13:06 USDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:13:06 + OnThreadComplete. | 2017-09-13 07:13:06 + OnThreadComplete. | 2017-09-13 07:13:06 + OnThreadComplete. | 2017-09-13 07:13:06 + OnThreadComplete. | 2017-09-13 07:13:06 + OnThreadComplete. | 2017-09-13 07:13:06 Listening socket (1192), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:14:00 * Listening socket (1192), port 0 | Closed. | 2017-09-13 07:14:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:14:00 * HTTP connection to ds01.ddfplus.com:80 (27) | Socket gracefully closed by remote side. | 2017-09-13 07:14:01 HTTP connection to ds01.ddfplus.com:80 (27) | Received socket Close event | 2017-09-13 07:14:01 HTTP connection to ds01.ddfplus.com:80 (27) | Initiating close of socket by core. | 2017-09-13 07:14:01 HTTP connection to ds01.ddfplus.com:80 (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-09-13 07:14:01 HTTP connection to ds01.ddfplus.com:80 (27) | Closed. | 2017-09-13 07:14:01 Listening socket (952), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:15:00 * Listening socket (952), port 0 | Closed. | 2017-09-13 07:15:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:15:00 * Listening socket (1208), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:16:00 * Listening socket (1208), port 0 | Closed. | 2017-09-13 07:16:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:16:00 * USDJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:16:13 USDJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:16:13 USDJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:16:13 USDJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:16:13 USDJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:16:13 USDJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:16:13 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2017-09-13 07:16:13 HD Request # 24 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2017-09-13 07:16:13 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\USDJPY.scid. This may take a while. | 2017-09-13 07:16:13 * HD Request # 24 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:16:13 HD Request # 24 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:16:13 Socket (30) | Creating socket. | 2017-09-13 07:16:13 Socket (30) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:16:13 HD Request # 24 | Setting DTC encoding to Binary VLS | 2017-09-13 07:16:24 HD Request # 24 | Sending historical data logon request message. | 2017-09-13 07:16:24 HD Request # 24 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: USDJPY | 2017-09-13 07:16:24 HD Request # 24 | Decompressing data. | 2017-09-13 07:16:24 HD Request # 24 | Receiving Intraday data for USDJPY starting at 2017-09-11 18:16:10 | 2017-09-13 07:16:24 HD Request # 24 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:12 | 2017-09-13 07:16:24 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:26 + OnThreadComplete. | 2017-09-13 07:16:26 Socket (30) | Initiating close of socket by core. | 2017-09-13 07:16:26 Socket (30) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:16:26 Socket (30) | Socket gracefully closed by remote side. | 2017-09-13 07:16:26 Socket (30) | Closed. | 2017-09-13 07:16:26 Historical data download thread signaled to stop. | 2017-09-13 07:16:26 HD Request # 24 | Received 408297 records from 2017-09-11 18:16:10 to 2017-09-13 07:16:26 (37.0 hours) and wrote 408295 records for USDJPY | 2017-09-13 07:16:26 Added 2 Time and Sales records to Intraday data file for USDJPY after download. | 2017-09-13 07:16:26 HD Request # 24 | Intraday download COMPLETE for USDJPY. Completion time: 13s. Unique request ID: 28 | 2017-09-13 07:16:26 Removed historical data download ID 28 | 2017-09-13 07:16:26 Real-time Intraday chart data file updates started for USDJPY | 2017-09-13 07:16:26 Intraday chart data file opened for USDJPY | 2017-09-13 07:16:26 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\USDJPY.scid | 2017-09-13 07:16:34 AUDJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:16:57 AUDJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:16:57 AUDJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:16:57 AUDJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:16:57 AUDJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:16:57 AUDJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:16:57 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:16:58 + OnThreadComplete. | 2017-09-13 07:16:58 Listening socket (1112), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:17:00 * Listening socket (1112), port 0 | Closed. | 2017-09-13 07:17:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:17:00 * AUDJPY [M] 240 Min #3 | Reloading chart. | 2017-09-13 07:17:31 AUDJPY [M] 240 Min #6 | Reloading chart. | 2017-09-13 07:17:31 AUDJPY [M] 240 Min #1 | Reloading chart. | 2017-09-13 07:17:31 AUDJPY [M] 240 Min #5 | Reloading chart. | 2017-09-13 07:17:31 AUDJPY [M] 240 Min #2 | Reloading chart. | 2017-09-13 07:17:31 AUDJPY [M] 240 Min #4 | Reloading chart. | 2017-09-13 07:17:31 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:33 + OnThreadComplete. | 2017-09-13 07:17:33 AUDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:17:46 AUDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:17:46 AUDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:17:46 AUDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:17:46 AUDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:17:46 AUDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 + OnThreadComplete. | 2017-09-13 07:17:46 AUDJPY [M] 240 Min #3 | Reloading chart. | 2017-09-13 07:17:51 AUDJPY [M] 240 Min #4 | Reloading chart. | 2017-09-13 07:17:51 AUDJPY [M] 240 Min #6 | Reloading chart. | 2017-09-13 07:17:51 AUDJPY [M] 240 Min #1 | Reloading chart. | 2017-09-13 07:17:51 AUDJPY [M] 240 Min #5 | Reloading chart. | 2017-09-13 07:17:51 AUDJPY [M] 240 Min #2 | Reloading chart. | 2017-09-13 07:17:51 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:52 + OnThreadComplete. | 2017-09-13 07:17:52 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-09-13 07:17:53 AUDJPY [M] 60 Min #2 | Reloading chart. | 2017-09-13 07:17:53 AUDJPY [M] 60 Min #5 | Reloading chart. | 2017-09-13 07:17:53 AUDJPY [M] 60 Min #1 | Reloading chart. | 2017-09-13 07:17:53 AUDJPY [M] 60 Min #6 | Reloading chart. | 2017-09-13 07:17:53 AUDJPY [M] 60 Min #4 | Reloading chart. | 2017-09-13 07:17:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:54 + OnThreadComplete. | 2017-09-13 07:17:54 AUDJPY [M] 60 Min #4 | Reloading chart. | 2017-09-13 07:17:56 AUDJPY [M] 60 Min #6 | Reloading chart. | 2017-09-13 07:17:56 AUDJPY [M] 60 Min #1 | Reloading chart. | 2017-09-13 07:17:56 AUDJPY [M] 60 Min #5 | Reloading chart. | 2017-09-13 07:17:56 AUDJPY [M] 60 Min #2 | Reloading chart. | 2017-09-13 07:17:56 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:57 + OnThreadComplete. | 2017-09-13 07:17:57 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:57 + OnThreadComplete. | 2017-09-13 07:17:57 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:57 + OnThreadComplete. | 2017-09-13 07:17:57 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:57 + OnThreadComplete. | 2017-09-13 07:17:57 + Finished LoadSingleIntradayFile | 2017-09-13 07:17:57 + OnThreadComplete. | 2017-09-13 07:17:57 Listening socket (1324), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:18:00 * Listening socket (1324), port 0 | Closed. | 2017-09-13 07:18:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:18:00 * AUDJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:18:36 AUDJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:18:36 AUDJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:18:36 AUDJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:18:36 AUDJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:18:36 AUDJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:18:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:18:37 + OnThreadComplete. | 2017-09-13 07:18:37 Listening socket (1504), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:19:00 * Listening socket (1504), port 0 | Closed. | 2017-09-13 07:19:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:19:00 * Listening socket (1524), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:20:00 * Listening socket (1524), port 0 | Closed. | 2017-09-13 07:20:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:20:00 * Listening socket (1760), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:21:00 * Listening socket (1760), port 0 | Closed. | 2017-09-13 07:21:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:21:00 * Listening socket (1900), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:22:00 * Listening socket (1900), port 0 | Closed. | 2017-09-13 07:22:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:22:00 * Listening socket (1744), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:23:00 * Listening socket (1744), port 0 | Closed. | 2017-09-13 07:23:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:23:00 * Listening socket (2024), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:24:00 * Listening socket (2024), port 0 | Closed. | 2017-09-13 07:24:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:24:00 * Listening socket (2000), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:25:00 * Listening socket (2000), port 0 | Closed. | 2017-09-13 07:25:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:25:00 * Listening socket (1476), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:26:00 * Listening socket (1476), port 0 | Closed. | 2017-09-13 07:26:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:26:00 * Listening socket (1544), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:27:00 * Listening socket (1544), port 0 | Closed. | 2017-09-13 07:27:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:27:00 * Listening socket (1520), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:28:00 * Listening socket (1520), port 0 | Closed. | 2017-09-13 07:28:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:28:00 * Listening socket (1652), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:29:00 * Listening socket (1652), port 0 | Closed. | 2017-09-13 07:29:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:29:00 * AUDNZD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:29:25 Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2017-09-13 07:29:25 HD Request # 25 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2017-09-13 07:29:25 HD Request # 25 | Download start date-time: 2017-09-12 19:36:05.000 | 2017-09-13 07:29:25 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:29:25 Socket (33) | Creating socket. | 2017-09-13 07:29:25 Socket (33) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:29:25 AUDNZD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:29:25 AUDNZD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:29:25 AUDNZD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:29:25 AUDNZD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:29:25 AUDNZD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:29:25 HD Request # 25 | Setting DTC encoding to Binary VLS | 2017-09-13 07:29:25 HD Request # 25 | Sending historical data logon request message. | 2017-09-13 07:29:25 HD Request # 25 | Requesting Intraday data. Start date-time: 2017-09-12 19:36:05. Record interval: 0. Symbol: AUDNZD | 2017-09-13 07:29:25 HD Request # 25 | Decompressing data. | 2017-09-13 07:29:25 HD Request # 25 | Receiving Intraday data for AUDNZD starting at 2017-09-12 19:36:05 | 2017-09-13 07:29:25 HD Request # 25 | Timestamp of first Intraday data file record written: 2017-09-12 19:36:06 | 2017-09-13 07:29:25 Socket (33) | Initiating close of socket by core. | 2017-09-13 07:29:25 Socket (33) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:29:25 Socket (33) | Socket gracefully closed by remote side. | 2017-09-13 07:29:25 Historical data download thread signaled to stop. | 2017-09-13 07:29:25 Socket (33) | Closed. | 2017-09-13 07:29:25 HD Request # 25 | Received 74845 records from 2017-09-12 19:36:05 to 2017-09-13 07:29:19 (11.9 hours) and wrote 74843 records for AUDNZD | 2017-09-13 07:29:25 Added 1 Time and Sales records to Intraday data file for AUDNZD after download. | 2017-09-13 07:29:25 HD Request # 25 | Intraday download COMPLETE for AUDNZD. Completion time: 0s. Unique request ID: 29 | 2017-09-13 07:29:25 Removed historical data download ID 29 | 2017-09-13 07:29:25 Real-time Intraday chart data file updates started for AUDNZD | 2017-09-13 07:29:25 Intraday chart data file opened for AUDNZD | 2017-09-13 07:29:25 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:26 + OnThreadComplete. | 2017-09-13 07:29:26 AUDUSD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:29:29 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2017-09-13 07:29:29 HD Request # 26 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2017-09-13 07:29:29 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\AUDUSD.scid. This may take a while. | 2017-09-13 07:29:29 * HD Request # 26 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:29:29 HD Request # 26 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:29:29 Socket (34) | Creating socket. | 2017-09-13 07:29:29 Socket (34) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:29:29 AUDUSD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:29:29 AUDUSD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:29:29 AUDUSD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:29:29 AUDUSD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:29:29 AUDUSD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:29:29 HD Request # 26 | Setting DTC encoding to Binary VLS | 2017-09-13 07:29:36 HD Request # 26 | Sending historical data logon request message. | 2017-09-13 07:29:36 HD Request # 26 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: AUDUSD | 2017-09-13 07:29:36 HD Request # 26 | Decompressing data. | 2017-09-13 07:29:36 HD Request # 26 | Receiving Intraday data for AUDUSD starting at 2017-09-11 18:16:10 | 2017-09-13 07:29:36 HD Request # 26 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:12 | 2017-09-13 07:29:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 Socket (34) | Initiating close of socket by core. | 2017-09-13 07:29:37 Socket (34) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:29:37 Socket (34) | Socket gracefully closed by remote side. | 2017-09-13 07:29:37 Historical data download thread signaled to stop. | 2017-09-13 07:29:37 Socket (34) | Closed. | 2017-09-13 07:29:37 HD Request # 26 | Received 258614 records from 2017-09-11 18:16:10 to 2017-09-13 07:29:38 (37.2 hours) and wrote 258613 records for AUDUSD | 2017-09-13 07:29:37 Added 2 Time and Sales records to Intraday data file for AUDUSD after download. | 2017-09-13 07:29:37 HD Request # 26 | Intraday download COMPLETE for AUDUSD. Completion time: 8s. Unique request ID: 30 | 2017-09-13 07:29:37 Removed historical data download ID 30 | 2017-09-13 07:29:37 Real-time Intraday chart data file updates started for AUDUSD | 2017-09-13 07:29:37 Intraday chart data file opened for AUDUSD | 2017-09-13 07:29:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:37 + OnThreadComplete. | 2017-09-13 07:29:37 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\AUDNZD.scid | 2017-09-13 07:29:46 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\AUDUSD.scid | 2017-09-13 07:29:46 CADJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:29:46 CADJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:29:46 CADJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:29:46 CADJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:29:46 CADJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:29:46 CADJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:29:46 Intraday data recording state for symbol CADJPY is set to download 'Pending'. | 2017-09-13 07:29:46 HD Request # 27 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2017-09-13 07:29:46 HD Request # 27 | Download start date-time: 2017-09-12 19:36:00.000 | 2017-09-13 07:29:46 HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:29:46 Socket (35) | Creating socket. | 2017-09-13 07:29:46 Socket (35) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:29:46 HD Request # 27 | Setting DTC encoding to Binary VLS | 2017-09-13 07:29:46 HD Request # 27 | Sending historical data logon request message. | 2017-09-13 07:29:46 HD Request # 27 | Requesting Intraday data. Start date-time: 2017-09-12 19:36:00. Record interval: 0. Symbol: CADJPY | 2017-09-13 07:29:46 HD Request # 27 | Decompressing data. | 2017-09-13 07:29:46 HD Request # 27 | Receiving Intraday data for CADJPY starting at 2017-09-12 19:36:00 | 2017-09-13 07:29:46 HD Request # 27 | Timestamp of first Intraday data file record written: 2017-09-12 19:36:07 | 2017-09-13 07:29:46 Socket (35) | Initiating close of socket by core. | 2017-09-13 07:29:46 Socket (35) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:29:46 Socket (35) | Socket gracefully closed by remote side. | 2017-09-13 07:29:46 Historical data download thread signaled to stop. | 2017-09-13 07:29:46 Socket (35) | Closed. | 2017-09-13 07:29:46 HD Request # 27 | Received 63331 records from 2017-09-12 19:36:00 to 2017-09-13 07:29:45 (11.9 hours) and wrote 63325 records for CADJPY | 2017-09-13 07:29:46 HD Request # 27 | Intraday download COMPLETE for CADJPY. Completion time: 0s. Unique request ID: 31 | 2017-09-13 07:29:46 Removed historical data download ID 31 | 2017-09-13 07:29:46 Real-time Intraday chart data file updates started for CADJPY | 2017-09-13 07:29:46 Intraday chart data file opened for CADJPY | 2017-09-13 07:29:46 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:47 + OnThreadComplete. | 2017-09-13 07:29:47 AUDUSD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:29:52 AUDUSD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:29:52 AUDUSD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:29:52 AUDUSD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:29:52 AUDUSD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:29:52 AUDUSD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:29:52 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:53 + OnThreadComplete. | 2017-09-13 07:29:53 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\CADJPY.scid | 2017-09-13 07:29:56 CADJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:29:58 CADJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:29:58 CADJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:29:58 CADJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:29:58 CADJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:29:58 CADJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:29:58 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 + Finished LoadSingleIntradayFile | 2017-09-13 07:29:59 + OnThreadComplete. | 2017-09-13 07:29:59 Listening socket (1548), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:30:00 * Listening socket (1548), port 0 | Closed. | 2017-09-13 07:30:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:30:00 * SC Data - All Services | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2017-09-13 07:30:06 EURCAD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:30:06 EURCAD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:30:06 EURCAD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:30:06 EURCAD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:30:06 EURCAD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:30:06 EURCAD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:30:06 Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2017-09-13 07:30:06 HD Request # 28 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2017-09-13 07:30:06 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\EURCAD.scid. This may take a while. | 2017-09-13 07:30:06 * HD Request # 28 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:30:06 HD Request # 28 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:30:06 Socket (37) | Creating socket. | 2017-09-13 07:30:06 Socket (37) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:30:06 HD Request # 28 | Setting DTC encoding to Binary VLS | 2017-09-13 07:30:19 HD Request # 28 | Sending historical data logon request message. | 2017-09-13 07:30:19 HD Request # 28 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: EURCAD | 2017-09-13 07:30:19 HD Request # 28 | Decompressing data. | 2017-09-13 07:30:19 HD Request # 28 | Receiving Intraday data for EURCAD starting at 2017-09-11 18:16:10 | 2017-09-13 07:30:19 HD Request # 28 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:12 | 2017-09-13 07:30:19 Socket (37) | Initiating close of socket by core. | 2017-09-13 07:30:19 Socket (37) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:30:19 Socket (37) | Socket gracefully closed by remote side. | 2017-09-13 07:30:19 Historical data download thread signaled to stop. | 2017-09-13 07:30:19 Socket (37) | Closed. | 2017-09-13 07:30:19 HD Request # 28 | Received 284378 records from 2017-09-11 18:16:10 to 2017-09-13 07:30:21 (37.2 hours) and wrote 284376 records for EURCAD | 2017-09-13 07:30:19 Added 1 Time and Sales records to Intraday data file for EURCAD after download. | 2017-09-13 07:30:19 HD Request # 28 | Intraday download COMPLETE for EURCAD. Completion time: 13s. Unique request ID: 32 | 2017-09-13 07:30:19 Removed historical data download ID 32 | 2017-09-13 07:30:19 Real-time Intraday chart data file updates started for EURCAD | 2017-09-13 07:30:19 Intraday chart data file opened for EURCAD | 2017-09-13 07:30:19 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 + Finished LoadSingleIntradayFile | 2017-09-13 07:30:20 + OnThreadComplete. | 2017-09-13 07:30:20 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURCAD.scid | 2017-09-13 07:30:28 Listening socket (1468), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:31:00 * Listening socket (1468), port 0 | Closed. | 2017-09-13 07:31:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:31:00 * EURCHF [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:31:29 Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2017-09-13 07:31:29 HD Request # 29 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2017-09-13 07:31:29 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\EURCHF.scid. This may take a while. | 2017-09-13 07:31:29 * HD Request # 29 | Download start date-time: 2017-09-11 18:16:11.000 | 2017-09-13 07:31:29 HD Request # 29 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:31:29 Socket (38) | Creating socket. | 2017-09-13 07:31:29 Socket (38) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:31:29 EURCHF [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:31:29 EURCHF [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:31:29 EURCHF [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:31:29 EURCHF [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:31:29 EURCHF [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:31:29 HD Request # 29 | Setting DTC encoding to Binary VLS | 2017-09-13 07:31:36 HD Request # 29 | Sending historical data logon request message. | 2017-09-13 07:31:36 HD Request # 29 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:11. Record interval: 0. Symbol: EURCHF | 2017-09-13 07:31:36 HD Request # 29 | Decompressing data. | 2017-09-13 07:31:36 HD Request # 29 | Receiving Intraday data for EURCHF starting at 2017-09-11 18:16:11 | 2017-09-13 07:31:36 HD Request # 29 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:12 | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:36 + OnThreadComplete. | 2017-09-13 07:31:36 Socket (38) | Initiating close of socket by core. | 2017-09-13 07:31:38 Socket (38) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:31:38 Socket (38) | Socket gracefully closed by remote side. | 2017-09-13 07:31:38 Socket (38) | Closed. | 2017-09-13 07:31:38 Historical data download thread signaled to stop. | 2017-09-13 07:31:38 HD Request # 29 | Received 283956 records from 2017-09-11 18:16:11 to 2017-09-13 07:31:35 (37.3 hours) and wrote 283955 records for EURCHF | 2017-09-13 07:31:38 Added 17 Time and Sales records to Intraday data file for EURCHF after download. | 2017-09-13 07:31:38 HD Request # 29 | Intraday download COMPLETE for EURCHF. Completion time: 9s. Unique request ID: 33 | 2017-09-13 07:31:38 Removed historical data download ID 33 | 2017-09-13 07:31:38 Real-time Intraday chart data file updates started for EURCHF | 2017-09-13 07:31:38 Intraday chart data file opened for EURCHF | 2017-09-13 07:31:38 EURGBP [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:31:41 EURGBP [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:31:41 EURGBP [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:31:41 EURGBP [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:31:41 EURGBP [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:31:41 EURGBP [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:31:41 Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2017-09-13 07:31:41 HD Request # 30 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2017-09-13 07:31:41 HD Request # 30 | Download start date-time: 2017-09-12 19:36:04.000 | 2017-09-13 07:31:41 HD Request # 30 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:31:41 Socket (39) | Creating socket. | 2017-09-13 07:31:41 Socket (39) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:31:41 HD Request # 30 | Setting DTC encoding to Binary VLS | 2017-09-13 07:31:42 HD Request # 30 | Sending historical data logon request message. | 2017-09-13 07:31:42 HD Request # 30 | Requesting Intraday data. Start date-time: 2017-09-12 19:36:04. Record interval: 0. Symbol: EURGBP | 2017-09-13 07:31:42 HD Request # 30 | Decompressing data. | 2017-09-13 07:31:42 HD Request # 30 | Receiving Intraday data for EURGBP starting at 2017-09-12 19:36:04 | 2017-09-13 07:31:42 HD Request # 30 | Timestamp of first Intraday data file record written: 2017-09-12 19:36:29 | 2017-09-13 07:31:42 Socket (39) | Initiating close of socket by core. | 2017-09-13 07:31:42 Socket (39) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:31:42 Socket (39) | Socket gracefully closed by remote side. | 2017-09-13 07:31:42 Historical data download thread signaled to stop. | 2017-09-13 07:31:42 Socket (39) | Closed. | 2017-09-13 07:31:42 HD Request # 30 | Received 89357 records from 2017-09-12 19:36:04 to 2017-09-13 07:31:42 (11.9 hours) and wrote 89356 records for EURGBP | 2017-09-13 07:31:42 Added 5 Time and Sales records to Intraday data file for EURGBP after download. | 2017-09-13 07:31:42 HD Request # 30 | Intraday download COMPLETE for EURGBP. Completion time: 0s. Unique request ID: 34 | 2017-09-13 07:31:42 Removed historical data download ID 34 | 2017-09-13 07:31:42 Real-time Intraday chart data file updates started for EURGBP | 2017-09-13 07:31:42 Intraday chart data file opened for EURGBP | 2017-09-13 07:31:42 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 + Finished LoadSingleIntradayFile | 2017-09-13 07:31:43 + OnThreadComplete. | 2017-09-13 07:31:43 EURJPY [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:31:46 Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2017-09-13 07:31:46 HD Request # 31 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2017-09-13 07:31:46 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\EURJPY.scid. This may take a while. | 2017-09-13 07:31:46 * HD Request # 31 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:31:46 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURCHF.scid | 2017-09-13 07:31:46 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURGBP.scid | 2017-09-13 07:31:46 HD Request # 31 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:31:46 Socket (40) | Creating socket. | 2017-09-13 07:31:46 Socket (40) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:31:46 HD Request # 31 | Setting DTC encoding to Binary VLS | 2017-09-13 07:31:46 HD Request # 31 | Sending historical data logon request message. | 2017-09-13 07:31:46 EURJPY [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:31:46 EURJPY [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:31:46 EURJPY [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:31:46 EURJPY [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:31:46 EURJPY [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:31:46 Listening socket (1156), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:32:09 * Listening socket (1156), port 0 | Closed. | 2017-09-13 07:32:09 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:32:09 * HD Request # 31 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: EURJPY | 2017-09-13 07:32:09 HD Request # 31 | Decompressing data. | 2017-09-13 07:32:09 HD Request # 31 | Receiving Intraday data for EURJPY starting at 2017-09-11 18:16:10 | 2017-09-13 07:32:09 HD Request # 31 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:12 | 2017-09-13 07:32:09 Socket (40) | Initiating close of socket by core. | 2017-09-13 07:32:09 Socket (40) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:32:09 Socket (40) | Socket gracefully closed by remote side. | 2017-09-13 07:32:09 Historical data download thread signaled to stop. | 2017-09-13 07:32:09 Socket (40) | Closed. | 2017-09-13 07:32:09 HD Request # 31 | Received 667161 records from 2017-09-11 18:16:10 to 2017-09-13 07:32:11 (37.3 hours) and wrote 667153 records for EURJPY | 2017-09-13 07:32:09 Added 2 Time and Sales records to Intraday data file for EURJPY after download. | 2017-09-13 07:32:09 HD Request # 31 | Intraday download COMPLETE for EURJPY. Completion time: 23s. Unique request ID: 35 | 2017-09-13 07:32:09 Removed historical data download ID 35 | 2017-09-13 07:32:09 Real-time Intraday chart data file updates started for EURJPY | 2017-09-13 07:32:09 Intraday chart data file opened for EURJPY | 2017-09-13 07:32:09 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:11 + OnThreadComplete. | 2017-09-13 07:32:11 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:12 + OnThreadComplete. | 2017-09-13 07:32:12 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:12 + OnThreadComplete. | 2017-09-13 07:32:12 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:12 + OnThreadComplete. | 2017-09-13 07:32:12 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:12 + OnThreadComplete. | 2017-09-13 07:32:12 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:12 + OnThreadComplete. | 2017-09-13 07:32:12 EURNZD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:32:15 EURNZD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:32:15 EURNZD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:32:15 EURNZD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:32:15 EURNZD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:32:15 EURNZD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:32:15 Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2017-09-13 07:32:15 HD Request # 32 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2017-09-13 07:32:15 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\EURNZD.scid. This may take a while. | 2017-09-13 07:32:15 * HD Request # 32 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:32:15 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURJPY.scid | 2017-09-13 07:32:15 HD Request # 32 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:32:15 Socket (41) | Creating socket. | 2017-09-13 07:32:15 Socket (41) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:32:15 HD Request # 32 | Setting DTC encoding to Binary VLS | 2017-09-13 07:32:21 HD Request # 32 | Sending historical data logon request message. | 2017-09-13 07:32:21 HD Request # 32 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: EURNZD | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 HD Request # 32 | Decompressing data. | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:21 + OnThreadComplete. | 2017-09-13 07:32:21 HD Request # 32 | Receiving Intraday data for EURNZD starting at 2017-09-11 18:16:10 | 2017-09-13 07:32:21 HD Request # 32 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:17 | 2017-09-13 07:32:21 Socket (41) | Initiating close of socket by core. | 2017-09-13 07:32:22 Socket (41) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:32:22 Socket (41) | Socket gracefully closed by remote side. | 2017-09-13 07:32:22 Socket (41) | Closed. | 2017-09-13 07:32:22 Historical data download thread signaled to stop. | 2017-09-13 07:32:22 HD Request # 32 | Received 178755 records from 2017-09-11 18:16:10 to 2017-09-13 07:32:23 (37.3 hours) and wrote 178754 records for EURNZD | 2017-09-13 07:32:22 Added 3 Time and Sales records to Intraday data file for EURNZD after download. | 2017-09-13 07:32:22 HD Request # 32 | Intraday download COMPLETE for EURNZD. Completion time: 7s. Unique request ID: 36 | 2017-09-13 07:32:22 Removed historical data download ID 36 | 2017-09-13 07:32:22 Real-time Intraday chart data file updates started for EURNZD | 2017-09-13 07:32:22 Intraday chart data file opened for EURNZD | 2017-09-13 07:32:22 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURNZD.scid | 2017-09-13 07:32:30 EURUSD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:32:34 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2017-09-13 07:32:34 HD Request # 33 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2017-09-13 07:32:34 HD Request # 33 | Download start date-time: 2017-09-12 19:36:04.000 | 2017-09-13 07:32:34 HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2017-09-13 07:32:34 Socket (42) | Creating socket. | 2017-09-13 07:32:34 Socket (42) | Connecting to IP: 192.81.56.146. | 2017-09-13 07:32:34 EURUSD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:32:34 EURUSD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:32:34 EURUSD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:32:34 EURUSD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:32:34 EURUSD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:32:34 HD Request # 33 | Setting DTC encoding to Binary VLS | 2017-09-13 07:32:34 HD Request # 33 | Sending historical data logon request message. | 2017-09-13 07:32:34 HD Request # 33 | Requesting Intraday data. Start date-time: 2017-09-12 19:36:04. Record interval: 0. Symbol: EURUSD | 2017-09-13 07:32:34 HD Request # 33 | Decompressing data. | 2017-09-13 07:32:34 HD Request # 33 | Receiving Intraday data for EURUSD starting at 2017-09-12 19:36:04 | 2017-09-13 07:32:34 HD Request # 33 | Timestamp of first Intraday data file record written: 2017-09-12 19:36:29 | 2017-09-13 07:32:34 Socket (42) | Initiating close of socket by core. | 2017-09-13 07:32:35 Socket (42) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:32:35 Socket (42) | Socket gracefully closed by remote side. | 2017-09-13 07:32:35 Historical data download thread signaled to stop. | 2017-09-13 07:32:35 Socket (42) | Closed. | 2017-09-13 07:32:35 HD Request # 33 | Received 119742 records from 2017-09-12 19:36:04 to 2017-09-13 07:32:35 (11.9 hours) and wrote 119741 records for EURUSD | 2017-09-13 07:32:35 Added 3 Time and Sales records to Intraday data file for EURUSD after download. | 2017-09-13 07:32:35 HD Request # 33 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 37 | 2017-09-13 07:32:35 Removed historical data download ID 37 | 2017-09-13 07:32:35 Real-time Intraday chart data file updates started for EURUSD | 2017-09-13 07:32:35 Intraday chart data file opened for EURUSD | 2017-09-13 07:32:35 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 + Finished LoadSingleIntradayFile | 2017-09-13 07:32:36 + OnThreadComplete. | 2017-09-13 07:32:36 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\EURUSD.scid | 2017-09-13 07:32:40 Listening socket (1468), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:33:00 * Listening socket (1468), port 0 | Closed. | 2017-09-13 07:33:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:33:00 * Listening socket (1244), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:34:00 * Listening socket (1244), port 0 | Closed. | 2017-09-13 07:34:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:34:00 * GBPAUD [M] 30 Min #3 | Reloading chart. | 2017-09-13 07:34:06 GBPAUD [M] 30 Min #1 | Reloading chart. | 2017-09-13 07:34:06 GBPAUD [M] 30 Min #5 | Reloading chart. | 2017-09-13 07:34:06 GBPAUD [M] 30 Min #4 | Reloading chart. | 2017-09-13 07:34:06 GBPAUD [M] 30 Min #2 | Reloading chart. | 2017-09-13 07:34:06 GBPAUD [M] 30 Min #6 | Reloading chart. | 2017-09-13 07:34:06 Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2017-09-13 07:34:06 HD Request # 34 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2017-09-13 07:34:06 Compressing file: C:\SierraChart - Copy for EOD Analysis\Data\GBPAUD.scid. This may take a while. | 2017-09-13 07:34:06 * HD Request # 34 | Download start date-time: 2017-09-11 18:16:10.000 | 2017-09-13 07:34:06 HD Request # 34 | Using server: ds3.sierracharts.com port 10150 | 2017-09-13 07:34:06 Socket (43) | Creating socket. | 2017-09-13 07:34:06 Socket (43) | Connecting to IP: 65.182.172.42. | 2017-09-13 07:34:06 HD Request # 34 | Setting DTC encoding to Binary VLS | 2017-09-13 07:34:14 HD Request # 34 | Sending historical data logon request message. | 2017-09-13 07:34:14 HD Request # 34 | Requesting Intraday data. Start date-time: 2017-09-11 18:16:10. Record interval: 0. Symbol: GBPAUD | 2017-09-13 07:34:14 HD Request # 34 | Decompressing data. | 2017-09-13 07:34:14 HD Request # 34 | Receiving Intraday data for GBPAUD starting at 2017-09-11 18:16:10 | 2017-09-13 07:34:14 HD Request # 34 | Timestamp of first Intraday data file record written: 2017-09-11 18:16:19 | 2017-09-13 07:34:14 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 + Finished LoadSingleIntradayFile | 2017-09-13 07:34:15 + OnThreadComplete. | 2017-09-13 07:34:15 Socket (43) | Initiating close of socket by core. | 2017-09-13 07:34:16 Historical data download thread signaled to stop. | 2017-09-13 07:34:16 Socket (43) | Shutdown started. Waiting for graceful close. | 2017-09-13 07:34:16 Socket (43) | Socket gracefully closed by remote side. | 2017-09-13 07:34:16 Socket (43) | Closed. | 2017-09-13 07:34:16 HD Request # 34 | Received 328386 records from 2017-09-11 18:16:10 to 2017-09-13 07:34:17 (37.3 hours) and wrote 328385 records for GBPAUD | 2017-09-13 07:34:16 HD Request # 34 | Intraday download COMPLETE for GBPAUD. Completion time: 10s. Unique request ID: 38 | 2017-09-13 07:34:16 Removed historical data download ID 38 | 2017-09-13 07:34:16 Real-time Intraday chart data file updates started for GBPAUD | 2017-09-13 07:34:16 Intraday chart data file opened for GBPAUD | 2017-09-13 07:34:16 Opened cached Intraday file: C:\SierraChart - Copy for EOD Analysis\Data\GBPAUD.scid | 2017-09-13 07:34:24 GBPAUD [M] Daily #5 | Reloading chart. | 2017-09-13 07:34:50 GBPAUD [M] Daily #1 | Reloading chart. | 2017-09-13 07:34:50 GBPAUD [M] Daily #6 | Reloading chart. | 2017-09-13 07:34:50 GBPAUD [M] Daily #3 | Reloading chart. | 2017-09-13 07:34:50 GBPAUD [M] Daily #2 | Reloading chart. | 2017-09-13 07:34:50 GBPAUD [M] Daily #4 | Reloading chart. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 + OnThreadComplete. | 2017-09-13 07:34:50 AUDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:34:51 AUDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:34:51 AUDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:34:51 AUDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:34:51 AUDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:34:51 AUDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:34:51 + OnThreadComplete. | 2017-09-13 07:34:51 + OnThreadComplete. | 2017-09-13 07:34:52 + OnThreadComplete. | 2017-09-13 07:34:52 + OnThreadComplete. | 2017-09-13 07:34:52 + OnThreadComplete. | 2017-09-13 07:34:52 + OnThreadComplete. | 2017-09-13 07:34:52 AUDJPY [M] Daily #3 | Reloading chart. | 2017-09-13 07:35:00 + OnThreadComplete. | 2017-09-13 07:35:00 Listening socket (1308), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:35:00 * Listening socket (1308), port 0 | Closed. | 2017-09-13 07:35:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:35:00 * AUDJPY [M] Daily #5 | Reloading chart. | 2017-09-13 07:35:01 AUDJPY [M] Daily #6 | Reloading chart. | 2017-09-13 07:35:01 AUDJPY [M] Daily #1 | Reloading chart. | 2017-09-13 07:35:01 AUDJPY [M] Daily #4 | Reloading chart. | 2017-09-13 07:35:01 AUDJPY [M] Daily #2 | Reloading chart. | 2017-09-13 07:35:01 + OnThreadComplete. | 2017-09-13 07:35:02 + OnThreadComplete. | 2017-09-13 07:35:02 + OnThreadComplete. | 2017-09-13 07:35:02 + OnThreadComplete. | 2017-09-13 07:35:02 + OnThreadComplete. | 2017-09-13 07:35:02 Listening socket (1140), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:36:00 * Listening socket (1140), port 0 | Closed. | 2017-09-13 07:36:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:36:00 * Listening socket (1152), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:37:00 * Listening socket (1152), port 0 | Closed. | 2017-09-13 07:37:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:37:00 * Listening socket (1140), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:38:00 * Listening socket (1140), port 0 | Closed. | 2017-09-13 07:38:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:38:00 * Remote instance connected: C:\SierraChart\SierraChart.exe | 2017-09-13 07:38:24 Listening socket (1656), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:39:00 * Listening socket (1656), port 0 | Closed. | 2017-09-13 07:39:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:39:00 * Listening socket (1280), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:40:00 * Listening socket (1280), port 0 | Closed. | 2017-09-13 07:40:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:40:00 * Listening socket (1180), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:41:00 * Listening socket (1180), port 0 | Closed. | 2017-09-13 07:41:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:41:00 * Listening socket (1552), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:42:01 * Listening socket (1552), port 0 | Closed. | 2017-09-13 07:42:01 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:42:01 * Listening socket (1180), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:43:00 * Listening socket (1180), port 0 | Closed. | 2017-09-13 07:43:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:43:00 * Listening socket (1180), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:44:00 * Listening socket (1180), port 0 | Closed. | 2017-09-13 07:44:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:44:00 * Listening socket (1776), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:45:00 * Listening socket (1776), port 0 | Closed. | 2017-09-13 07:45:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:45:00 * Listening socket (1008), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:46:00 * Listening socket (1008), port 0 | Closed. | 2017-09-13 07:46:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:46:00 * Listening socket (1308), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:47:00 * Listening socket (1308), port 0 | Closed. | 2017-09-13 07:47:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:47:00 * Listening socket (584), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:48:00 * Listening socket (584), port 0 | Closed. | 2017-09-13 07:48:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:48:00 * Listening socket (1192), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:49:00 * Listening socket (1192), port 0 | Closed. | 2017-09-13 07:49:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:49:00 * Listening socket (1656), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:50:01 * Listening socket (1656), port 0 | Closed. | 2017-09-13 07:50:01 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:50:01 * SC Data - All Services | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2017-09-13 07:50:06 Listening socket (1656), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:51:00 * Listening socket (1656), port 0 | Closed. | 2017-09-13 07:51:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:51:00 * Listening socket (1656), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:52:00 * Listening socket (1656), port 0 | Closed. | 2017-09-13 07:52:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:52:00 * Listening socket (672), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:53:00 * Listening socket (672), port 0 | Closed. | 2017-09-13 07:53:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:53:00 * Listening socket (672), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:54:00 * Listening socket (672), port 0 | Closed. | 2017-09-13 07:54:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:54:00 * Listening socket (1604), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:55:00 * Listening socket (1604), port 0 | Closed. | 2017-09-13 07:55:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:55:00 * Listening socket (1140), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:56:00 * Listening socket (1140), port 0 | Closed. | 2017-09-13 07:56:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:56:00 * Listening socket (1456), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:57:00 * Listening socket (1456), port 0 | Closed. | 2017-09-13 07:57:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:57:00 * Listening socket (1552), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:58:00 * Listening socket (1552), port 0 | Closed. | 2017-09-13 07:58:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:58:00 * Listening socket (1720), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 07:59:00 * Listening socket (1720), port 0 | Closed. | 2017-09-13 07:59:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 07:59:00 * Listening socket (1692), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 08:00:00 * Listening socket (1692), port 0 | Closed. | 2017-09-13 08:00:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 08:00:00 * Listening socket (1172), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 08:01:00 * Listening socket (1172), port 0 | Closed. | 2017-09-13 08:01:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 08:01:00 * Listening socket (1284), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 08:02:00 * Listening socket (1284), port 0 | Closed. | 2017-09-13 08:02:00 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 08:02:00 * Listening socket (1284), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 08:03:01 * Listening socket (1284), port 0 | Closed. | 2017-09-13 08:03:01 DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 08:03:01 * Sierra Chart Support |
[2017-09-13 18:10:57] |
To resolve these error messages: DTC Protocol Server failed to start listening on port 11099. | 2017-09-13 08:02:00 *
Listening socket (1284), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2017-09-13 08:03:01 * Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/NewInstance.php#ResolvingDTCProtocolServerPortNumberConflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
