Date/Time: Wed, 15 Jan 2025 20:51:02 +0000
symbol name
View Count: 1025
[2017-09-13 11:27:54] |
AKR - Posts: 523 |
is there a possibility to get a symbol´s name somewhere on the chart. because when you have a screen with like 10 symbols it would be useful. Date Time Of Last Edit: 2017-09-13 11:28:02
[2017-09-13 15:26:57] |
Xfanman1 - Posts: 320 |
Go into your Studies and add the "Symbol Display" Study. You can set the size and background however you'd like.
[2017-09-13 15:29:27] |
AKR - Posts: 523 |
thx
[2017-09-13 17:21:52] |
Here is the relevant documentation: Symbol Display Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
