Date/Time: Wed, 15 Jan 2025 21:04:08 +0000
Timescale
View Count: 800
[2017-09-13 07:02:40] |
User22414 - Posts: 66 |
I have an incorrect time scale in my chart on the x axis. The chart starts at 6:00 AM instead of 8:00 AM. Where can you set it?
[2017-09-13 07:17:43] |
This is controlled through Chart >> Chart Settings >> Session Times: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
