Date/Time: Wed, 15 Jan 2025 20:51:55 +0000
Keeping last candle next to profile
View Count: 933
[2017-09-13 01:22:21] |
User341584 - Posts: 44 |
I have multiple profiles on right side of chart. How can I keep the current price candle tight next the the profiles? If I use 'Lock Fill Space' its nice unless I change the zoom (holding & dragging the time scale on x-axis of chart)..Then the current printing candle gets moved to left of screen and doesn't stay tight to the right? Am I missing something? Or is there another method to achieve results I'm looking for? TIA |
[2017-09-13 02:18:58] |
The space on the right side of the chart will vary as you change the spacing between the chart bars. There is not a way to prevent that if that is what you are referring to.
