Date/Time: Wed, 15 Jan 2025 20:49:21 +0000
Can't edit volume profile
View Count: 1247
[2017-09-12 17:42:10] |
User104854 - Posts: 457 |
Hi. I can't edit a drawn volume profile on one of my charts. It works on other charts. Can you tell me which setting I should look at to fix it?
[2017-09-12 18:46:27] |
We do not know what you mean by editing a drawn volume profile. Edit in what way? Do you mean you want to adjust the Study Settings for it?
[2017-09-12 19:54:50] |
When I click on it on the chart it does nothing. It doesn't highlight so that I can move or adjust it. On other charts when I click on a drawn profile I am able to adjust it on the chart, move it around, etc. That's what I want to do. Click on it and adjust the timeframe.
[2017-09-12 20:17:25] |
I fixed the problem. Created a new chart and copied the studies over. Hopefully it was just a fluke. You're off the hook.
[2017-09-12 20:51:08] |
Follow the detailed instructions here: Volume By Price Study: Modifying Manually Drawn Volume Profile Also make sure you are using the latest version of Sierra Chart because there have been some improvements with this functionality. For example, it was not previously possible to adjust a drawn volume profile by modifying its corners. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-12 20:52:19
