Date/Time: Wed, 15 Jan 2025 20:49:45 +0000
market depth
View Count: 869
[2017-09-12 11:54:42] |
User40526 - Posts: 166 |
Can I get more than 10 prices on the bid and ask on my DOM? I can't find anything in the documentation. Thanks
[2017-09-12 16:35:51] |
Only if that is being provided by the particular Data or Trading service you are using. We see you are using CTS and we do not think they are going to provide more than 10 levels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-12 16:35:54] |
