Date/Time: Wed, 15 Jan 2025 20:53:55 +0000
quote board volume question
View Count: 854
[2017-09-12 02:19:03] |
zippyzip - Posts: 293 |
hey not sure if there is another setting but my vol never matches or even close to actual vol , is there a setting i have to change to get it to match , thanks picture is my quote board compared to CME quote board |
2017-09-11_11-44.jpg / V - Attached On 2017-09-12 02:18:00 UTC - Size: 34.13 KB - 272 views |
[2017-09-12 04:43:10] |
We see you are using CQG and those fields of data are provided by CQG. There are no settings related to this. You might consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
