Date/Time: Wed, 15 Jan 2025 21:08:05 +0000
Couple of issues
View Count: 973
[2017-09-12 01:27:29] |
jimskin - Posts: 127 |
I have 10 windows tiled (horizontal). How do I get each candlestick/bar to auto-height in each window. At the moment, I have to drag each window up and down so I can see each chart.
[2017-09-12 03:59:32] |
The problem is you have altered the vertical scaling from the default as described here: Chart Scale and Scale Adjusting: Interactive Scaling You need to select Chart >> Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-12 04:25:07] |
Refer to this section here also: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
