Date/Time: Wed, 15 Jan 2025 21:12:12 +0000
[Programming Help] - Text Drawing, UseRelativeVerticalValues isn't in effect in Replay mode
View Count: 1077
[2017-09-11 03:34:51]
User735389 - Posts: 189
Draws everything at position 100
[2017-09-11 08:22:34]
This is something that you need to resolve from your side. The problem does not have to do with replay.
Refer to the documentation for that variable:
https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#UseRelativeVerticalValues
Date Time Of Last Edit: 2017-09-11 08:22:43
[2017-09-11 16:11:19]
I see. It looks like Replay mode has it's own independent settings for charts. Resetting the chart scale resolved this
[2017-09-11 16:21:29]
No, there is no independent scale setting for charts when replaying.
[2017-09-11 20:02:58]
The issue ended up being the chart not having enough Days To Load data relative to the date the replay is running at.
