Date/Time: Wed, 15 Jan 2025 20:53:24 +0000
BTCUSD-BITFINX symbol through
View Count: 680
[2017-09-10 20:00:42] |
User61576 - Posts: 445 |
when using thie in 5min time frame SC is getting stacked and while it's in realtime mode using the crypto datafeed, it's starts downloading historical data i don't have any problem with iqfeed data and many charts opened (tick data) do i have a problem with my machine? any click on SC is causing it to stck pls advice (i sent the log for you to check as well) thanks |
[2017-09-10 20:15:17] |
Do you mean Sierra Chart is freezing? If so, refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
