Date/Time: Wed, 15 Jan 2025 20:45:18 +0000
Control Bar 1 Problem
View Count: 718
[2017-09-09 23:11:27] |
User942178 - Posts: 25 |
I have a 3 minute & a 5 minute chart bar on control bar 1. As of Thursday, I can no longer activate the 3 minute chart from the control bar. I have removed the 3 minute and replaced it - it is still not working. Don't know why it suddenly stopped working. Thank you. |
[2017-09-11 17:15:45] |
Make sure the Intraday chart is currently open and active. And make sure the Control Bar button is properly configured: Control Bar: Custom Buttons for Intraday Chart Bar Period And you also need to put a control bar on a detached chart and use that control bar if you are working from a detached chart. Refer to: Control Bar: Window >> Control Bars >> Control Bar [1-12] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-11 17:16:09
