Date/Time: Fri, 24 Jan 2025 20:28:28 +0000
custom chart autobacktest
View Count: 878
[2017-09-09 14:16:21] |
User30743 - Posts: 365 |
i use a special Market Order timeframe which was build by a one trader as a custom chart studies - this chart collects data in the special format BID_ASK_TRADE_SYNC and the data are not accessible in the history, so i need to record them real time. that is not a problem. i recorded couple of days and now i would like to do autobacktest it with a simple custom study that i build. unfortunatelly, this custom chart is not possible to backtest (or it seems so) becaus sierra loads so long just to test one hour of the data the question is? why is it so? and how do i make it work? |
[2017-09-11 08:58:35] |
Refer to: https://www.sierrachart.com/index.php?page=doc/Backtesting.php#ImprovingPerformanceOverall Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
