Date/Time: Wed, 15 Jan 2025 20:59:02 +0000
Crosshair Style - Issue
View Count: 986
[2017-09-09 00:46:42] |
Marek F - Posts: 244 |
I updated SC from 1585 to 1606, and there is an issue with Crosshair Style. Can not be set the Dot Style.
Crosshair Style.png / V - Attached On 2017-09-09 00:45:54 UTC - Size: 48.47 KB - 344 views |
[2017-09-09 01:04:49] |
This is no longer supported if the line is one pixel in thickness. This was to resolve another issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-09 11:26:07] |
Could you please resolve this another issue in another way? The Crosshair with the Dot Style and one pixel is very very important for me. I need very fine lines. The Crosshair Horizontal Line with the Dot Style and 2 pixels width is good for me (even better than 1 pixel in previous versions), but Crosshair Vertical Line (Dot Style, 2 pixels width) has many short two-pixels lines. Maybe you could replace them by one-pixel dots? Thank you |
