Date/Time: Wed, 15 Jan 2025 21:00:13 +0000
automatic renew of 1 Additional System
View Count: 980
[2017-09-08 15:48:00] |
User30743 - Posts: 365 |
hi, how do i make automatic renew of 1 aditional system? currently i have bought version 5 for 2 machines till 22-4-2018 and month ago i added 1 aditional system (active until 13-9-2017. i want to make the 1 aditional system active till the same time as i have it for two machines -i need to record market depth data without interupriton, so i need one more system automatically renewing how will i do it? |
3 machines.JPG / V - Attached On 2017-09-08 15:46:39 UTC - Size: 110.29 KB - 372 views |
[2017-09-08 18:52:43] |
Sierra Chart - Max - Posts: 5778 |
You currently have 3 systems active. At the moment your balance is sufficient for 1 renewal for 31 days for 1 additional system. For the additional system to continue automatically renewing, you would need to add more funds to your Services Balance: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Sierra Chart Support Date Time Of Last Edit: 2017-09-08 18:53:18
[2017-09-09 11:05:17] |
yes, i will add. it is not a problem, the question is if it will renew automatically when it is set up the way i have it now
[2017-09-11 16:24:23] |
Yes, as long as you have a sufficient Services Balance.
Sierra Chart Support |
