Date/Time: Wed, 15 Jan 2025 19:56:28 +0000
Sierra Chart CQG date feed showing different data from Eurex official website
View Count: 1056
[2017-09-08 07:31:26] |
User391949 - Posts: 14 |
Hello, I know three people including me that are having issues with our charts as we all have 162.80 as our daily high for the December FGBL (Bund futures contract) on the 6th of September 2017, but on the Eurex official website the daily high is 162.84. When I switch off continuous futures contract-date rule rollover, back adjusted in the continuous contract section under chart settings, the chart appears to be correct, but I also know someone who has this setting enabled while still having 162.84 as his high. Please let me know what is going on? Surely we should all have the same chart under the same sierra chart settings and the with the same data feed? Thank you. |
[2017-09-08 07:57:46] |
You cannot make the kind of comparison that you are. Here is the chart set up as you specified: http://www.sierrachart.com/image.php?Image=1504857497774.png On 2017-09-06, that is the September contract in the chart. There is no way you can make a comparison to the official exchange data any longer when there are back adjustments being done. You are not going to get any matches at all. The other user should re-download the data for September and December following the instructions here to match what you have: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-08 07:59:39
[2017-09-08 07:58:35] |
The image in the prior post has been updated.
