Date/Time: Wed, 15 Jan 2025 19:35:00 +0000
number bars & indicator availability AMS Under the Radar
View Count: 765
[2017-09-08 07:26:17] |
User157312 - Posts: 9 |
Hi guys, I have been using Sierra for a few months and now I am trailing InvestorRT. My overall conclusion is that Sierra is much better value however there is a plugin which I really like in IRT which is made by AMS called Under the Radar. This shows you turning points and works well with Crude so far from what Ive seen Well I would like to find out if teh community have made such an indicator and or do they know how this indicator works if we could could create it? on AMS site it says they use a Algo to figure it out... Anyones thought would be handy Cheers Ray |
[2017-09-08 08:00:30] |
We have no information ourselves about this and we do not think any user would have any further information.
[2017-09-08 08:29:34] |
i hope some users do...
Date Time Of Last Edit: 2017-09-08 08:29:45
