Date/Time: Wed, 15 Jan 2025 22:50:57 +0000
Server side OCO with data feed with AMP Futures
View Count: 2379
[2017-09-07 21:23:25]
User157806 - Posts: 71
Just had a general question is this supported with CQG and Rithmic for sierra charts?
[2017-09-08 02:19:44]
This is supported with both CQG and Rithmic. But it needs to be enabled.
Refer to:
Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General)
[2017-09-08 02:21:16]
Thank you.
[2017-09-22 02:13:41]
In regards to the attached orders when the market closes each day if you are using lets say GTC order type for both the limit and stop will the attached order configuration also still apply in the new session when the market reopens? In other words can you pretty much use attached orders as GTC and keep the OCO in play even after the market closes going into the new session?
[2017-09-22 02:54:34]
Yes. But make sure the Attached Orders are actually set to be Good till Canceled:
Attached Orders: Time In Force
Date Time Of Last Edit: 2017-09-22 02:55:30
