Date/Time: Wed, 15 Jan 2025 19:44:30 +0000
Contract Rollover Issue?
View Count: 817
[2017-09-07 20:10:22] |
User585845 - Posts: 17 |
It's time to rollover from YMU17 to YMZ17 on my charts but when I do this I do not see any data from the previous contract. Is there a way to join the data from both contracts to make it continuous so I can still see data that occurred a couple weeks ago? Thanks.
[2017-09-08 00:28:22] |
Refer to this page for instructions: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-08 04:30:28] |
I am a little confused with the instructions, do I select Continuous Futures Contract - Date Rule Rollover or Continuous Futures Contract - Volume Based Rollover? Thanks for your help.
[2017-09-08 06:28:14] |
This is actually explained right here: Continuous Futures Contract Charts: Using Date Rule Rollover or Volume Based Rollover? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
