Date/Time: Wed, 15 Jan 2025 19:53:13 +0000
5 Minute Charts
View Count: 882
[2017-09-07 19:06:48] |
User612787 - Posts: 1 |
Hi, On sierra chart I have a 5 minute chart (20 days loaded) that shows differently than a 5 minute chart (20 days loaded) on TD's Thinkorswim. Why would these look different when it's the same ticker and the same time chart? Thanks in advance. |
[2017-09-07 19:27:49] |
Refer to help topic 43: Differences With Data and Chart Bars Between Services / Connections / Chart Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-07 19:36:14] |
We added some additional information to help topic 43 just now. So reload that page.
