Date/Time: Wed, 15 Jan 2025 21:04:06 +0000
RATIO
View Count: 4782
[2017-09-07 18:50:50] |
Deltareversal - Posts: 46 |
How can I set the RATIO value on each bar ?
[2017-09-07 19:24:55] |
How is the ratio calculated?
[2017-09-08 10:49:19] |
Ratio is a relationship between two numbers The ratio of numbers A and B can be expressed as A:B Ratio Number appears high in the candle bearish Ratio Number appears down in the candle bullish When the value of Ratio is a number between 29.0 and 0.71(The Ratio number is black). When the value of Ratio number above 30 (The Ratio number is blue). If possible to compare in addition to the number Ratio also a text message: Neutral Ratio (A number between 29.0 and 0.71) Ratio Bounds High (A number above 30) Ratio Bounds Low (A number between 0.70 and 0.0) |
Orderflows ratios.jpg / V - Attached On 2017-09-08 10:47:24 UTC - Size: 152.27 KB - 1737 views |
[2017-09-08 12:10:41] |
binaryduke - Posts: 373 |
This is a screenshot from Mike Valtos' orderflows.com order flow ratios study for Ninja Trader. This is available as a commercial custom study via: www.emojitrading.com/bar-ratio with various display options. The same numeric information has also become available recently within the standard Sierra Chart Numbers Bars Calculated Values study. Date Time Of Last Edit: 2017-09-08 12:11:48
[2017-09-11 16:39:26] |
Sierra Chart does have two new Numbers Bars Calculated Values Subgraphs for these: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions They are: Low Bid Volume Percent: High Ask Volume Percent: Here is the documentation for the study: Numbers Bars: Displaying Numeric Information Below Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
