Date/Time: Wed, 15 Jan 2025 19:44:39 +0000
Deleting Copy Chart Drawings
View Count: 778
[2017-09-07 17:11:56] |
User727034 - Posts: 21 |
I've copied all the drawings from one chart to another. Now I want to remove them (there are many). When i delete a drawing from the destination chart it becomes deleted from the source. How do I get around this? [i.e. there are only a few of the drawings on the source chart that I want to remain on the destination chart] Secondly : Is there an "undo" function or Key-shortcut? |
[2017-09-07 19:22:37] |
What you want to do is not supported. For Undo, refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#UndoingRedoing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
