Date/Time: Wed, 15 Jan 2025 19:55:54 +0000
CTS and SC login
View Count: 1011
[2017-09-07 17:06:03] |
Adam - Posts: 141 |
Can i be logged into CTS (Desktop) and be logged into Sierra Chart using the CTS login at the same time? With CQG it auto logs you out which is annoying as i use SC for charting only and CTS Options Pro for execution. Thanks |
[2017-09-07 17:50:36] |
Yes this is supported. There is an option in the CTS specific settings to perform a hardware identifier check to make this possible.
[2017-09-07 18:15:22] |
Adam - Posts: 141 |
Wow you just saved me 400 a month
[2017-09-07 19:43:57] |
This is good. There also is another connection model you can use to CTS which also allows you to use Sierra Chart and the CTS programs at the same time. Refer to: http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel CTS really is a good choice. If you need options support when using CTS, we can add that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-07 19:47:25] |
Adam - Posts: 141 |
That's great thanks How do you add the options support it's worthwhile doing that, thanks |
[2017-09-08 01:33:35] |
Yes we will work on support for CTS options. We will try to have that out in the next release. Should not be hard.
