Date/Time: Wed, 15 Jan 2025 19:53:51 +0000
SC Exchange Service + DTC/TWS
View Count: 1210
[2017-09-07 14:34:43] |
onnb - Posts: 662 |
If I want the following setups: Setup 1 1. DataFeed coming in from SC Exchange Data Service 2. Trading directed to DTC server or TWS/IB Is there a document that explains how to set this up? Setup 2 1. DataFeed coming in from IQFeed 2. Trading directed to DTC server or TWS/IB Setup 3 1. ForeEx data from TWS/IB 2. All the rest coming in from SC Exchange Data/IQFeed 2. Trading directed to DTC server or TWS/IB Are all these possible? Can you help with directly links to these? Date Time Of Last Edit: 2017-09-07 14:35:17
[2017-09-07 19:14:18] |
Setup 1/Setup 3. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Setup 2: This is not recommended but here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-07 23:42:31] |
onnb - Posts: 662 |
In the docs I see this: "Also be aware to receive CME data at reduced exchange fees, you must be connected to a live funded trading account." If I am connected to my own DTC Server for trading, I understand this won't work? The full setup I am thinking of is something like this: SC connected to my DTC Server My DTC Server would trade with IB directly SC would receive data from SC Exchange Data Feed With the setup above, would have to pay the full exchange fees? Meaning even if I connect once a month, because I am using SC with my own DTC server, I would need to pay the exchange fees? Date Time Of Last Edit: 2017-09-08 00:20:05
[2017-09-08 00:25:52] |
With the setup above, would have to pay the full exchange fees? Although we could try to get approval for what you are doing. But then we would have to have complete trust in what you are doing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-08 00:29:05] |
Actually, there is a solution to this. Just connect Sierra Chart once a month to the Interactive Brokers account. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount That will be the best thing to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
