Date/Time: Wed, 15 Jan 2025 19:36:10 +0000
Position Bar
View Count: 939
[2017-09-07 14:29:23] |
User54459 - Posts: 7 |
I use 2 charts. When I place a trade the position bar of the trade would appear on both charts. For some reason it does not how do I get this to do this again?? Thank You Ken |
[2017-09-07 19:01:42] |
Refer to this section here: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ViewingOrdersOnTheChart Also, refer to: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#HowAveragePriceForPositionsIsCalculatedAndUsed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
